1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: -- Motor move only one direction / Motor 6.2.2 / OMS58-4S / servo-tar 300 --
To: [email protected]
Date: Tue, 28 Aug 2007 17:16:50 +0200
Hello
I'm a beginner on EPICS.
I try to command a brushless motor with motor 6.2.2 through OMS58-4S VME card on EPICS 3.14.8.2 (brushless motor is not a stepper motor).
Actually, I can only move the motor in one direction.
I use for debug a ASCII ligne command.
I found on tech-talk (References: <[email protected]>)
http://www.aps.anl.gov/epics/tech-talk/2001/msg00140.php
that the first command must be: "AT HE KP.1 KD.3 KI0 LP0 HN"
After that i send a move relative positive or negative.
But the motor move always in one direction.
Asking QA command we show a direction have a correct value
AT MR20000 GO
AT QA -> OMS58>PNNH<
AT MR-20000 GO
AT QA -> OMS58>MNNH<
I monitor also analog signal (output voltage for servostar) on output OMS58-4S. I see for MR20000 a positive voltage and for MR-20000 I expect a negative voltage but i see a positive voltage more larger than the first.
Can somebody help me ? or have same troubles ?
thanks per advance
Jerome HOSSELET
begin:vcard
fn:Jerome HOSSELET
n:HOSSELET;Jerome
org:CNRS / IPHC;Electronique / Informatique
adr:;;23 rue du loess;Strasbourg;;67000;FRANCE
email;internet:[email protected]
title:Assistant Ingenieur
tel;work:03 88 10 65 30
tel;home:03 88 xx xx xx
tel;cell:06 60 xx xx xx
note;quoted-printable:Assistant Ing=C3=A9nieur =C3=A0 l' IPHC :=0D=0A=
	- Projet CMS=0D=0A=
	- Projet SPIRAL 2
x-mozilla-html:FALSE
url:http://ireswww.in2p3.fr/
version:2.1
end:vcard
Re: -- Motor move only one direction / Motor 6.2.2 / OMS58-4S / servo-tar 300 -- Kurt Goetze
Re: -- Motor move only one direction / Motor 6.2.2 / OMS58-4S / servo-tar 300 -- Ron Sluiter
Prev: comedi :) Heinrich du Toit
Next: Re: -- Motor move only one direction / Motor 6.2.2 / OMS58-4S / servo-tar 300 -- Kurt Goetze
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
