1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: comedi :)
To: TechTalk EPICS <[email protected]>
Date: Tue, 28 Aug 2007 15:14:24 +0200
Just to let you know (I have an idea somebody out there might be
interested)
I've started working on a Comedi asyn device support layer for epics.
http://www.comedi.org
I know there is some people out there that would like to either use this
and maybe contribute also.
I will hopefully setup a project on sourceforge soon.
If you have ideas you feel very strong about regarding this "driver"
please email me :)
I'm currently doing a c++ setup where 3 types of ports are available.
SingleAnalog
SingleDigital
Command - this is Comedi speak for streams
And then all options can be altered controlled by PVs or drvparams or
using asynOption interface.
It will support all of the asyn interfaces.
Even Octet - for string options/feedback - and also for digital stream
I/O.
The comedi instruction interface will not be supported at this stage.
ok well... beter get to programming :D
-Heinrich
Prev: gateway problem Yuichi ITOH
Next: -- Motor move only one direction / Motor 6.2.2 / OMS58-4S / servo-tar 300 -- jerome HOSSELET
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: gateway problem Noboru Yamamoto
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
