You need to declare a gpib interface in your stcmd, which you haven't
done. But before you do that you need to compile asyn with gpib support
(LINUX_GPIB=YES). Check the asyn docs. And before your do that you need
to install the linux-gpib libraries.
Finally while configuring /etc/gpib.conf, you need to
associate /dev/gpib0 with the "LO" name (yes that's el-zero!)
Good luck !
E
On Mon, 2007-08-27 at 14:58 -0700, Szalata, Zenon M. wrote:
> I am extremely new to EPICS. To learn EPICS, I am trying to created an IOC application which would run on linux RedHat Enterprise 3 platform. I have installed a National Instruments PCI-GPIB interface to which I have connected HP34401A multimeter. I have installed on the same computer National Instruments software package NI4882, which I believe is the device driver for the PCI-GPIB interface. In the package NI supplied two test programs, which I built and they work.
> I followed a tutorial "How to create EPICS device support for a simple serial or GPIB device" by Eric Norum to create a support module for the HP multimeter. Then I created a test application, as it is described in the same tutorial. I start the test application and this is what I get:
> !--------- start of program output ---------------------------------
> zms@esaux1 $ ../../bin/linux-x86/hpmm st.cmd
> #!../../bin/linux-x86/hpmm
> ## You may have to change hpmm to something else
> ## everywhere it appears in this file
> < envPaths
> epicsEnvSet(ARCH,"linux-x86")
> epicsEnvSet(IOC,"iochpmm")
> epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/esalib/app/epics/hpmm")
> epicsEnvSet(HPMM,"/afs/slac/g/esa/esalib/app/epics/modules/hpmm")
> epicsEnvSet(ASYN,"/afs/slac/g/esa/esalib/app/epics/support/asyn/4-3")
> epicsEnvSet(EPICS_BASE,"/afs/slac/package/epics/R3.14.6/base")
> cd /afs/slac.stanford.edu/g/esa/esalib/app/epics/hpmm
> ## Register all support components
> dbLoadDatabase("dbd/hpmm.dbd",0,0)
> hpmm_registerRecordDeviceDriver(pdbbase)
> ## Load record instances
> cd /afs/slac/g/esa/esalib/app/epics/modules/hpmm
> dbLoadRecords("db/devhpmm.db","P=HPMM:,R=,L=0,A=10")
> cd /afs/slac.stanford.edu/g/esa/esalib/app/epics/hpmm/iocBoot/iochpmm
> iocInit()
> ### EPICS IOC CORE built on Mar 6 2005
> ### EPICS R3.14.6 $R3-14-6$ $2004/05/28 19:27:47$
> Starting iocInit
> 2007/08/27 14:28:04.494 devSupportGpib:getDeviceInstance link 0 L0 failed asynManager:connectDevice port L0 not found
> HPMM:hpmm:idn: init_record : no driver for link 0
> HPMM:hpmm:read: init_record : no driver for link 0
> ## Start any sequence programs
> #seq sncxxx,"user=zmsHost"
> iocInit: All initialization complete
> epics>
> !---------- end of program output ---------------------------------------
> In the above, the GPIB number is 0, the instrument primary GPIB address is 10 and its secondary address is 0.
> I do not know how to make a connection between the NI4882 driver and the test application. I tried something as simpleminded as including a shared library, which is in /usr/local/lib/libgpibapi.so, in the build of the test application. This had no effect. The reason I tried that is because the NI test programs used that library when binaries are linked.
> Any help will be greatly appreciated.
> Zen
- RE: Soft IOC for A GPIB Instrument Szalata, Zenon M.
- Soft IOC for A GPIB Instrument Szalata, Zenon M.
Re: Soft IOC for A GPIB Instrument Benjamin Franksen
gateway problem Yuichi ITOH
<2007>
<2007>
