1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data
To: "'Dirk Zimoch'" <[email protected]>, "'Peter Zumbruch'" <[email protected]>
Cc: [email protected]
Date: Mon, 27 Aug 2007 10:03:51 -0600
Dirk,
Starting with R3.14.9 all of the wire format conversion code was centralized
into libCom/osi/osiWireFormat.h and libCom/osi/xxx/osdWireFormat.h.
Currently, most OS use libCom/osi/defualt/osdWireFormat.h which has this
code (the only exception currently is VMS).
#if defined (_M_IX86) || defined (_X86_) || defined (__i386__) || defined
(_X86_64_) || defined (_M_AMD64)
#	define EPICS_LITTLE_ENDIAN
#elif ( defined (__ALPHA) || defined (__alpha) )
#elif defined (__arm__)
#else
#	define EPICS_BIG_ENDIAN
#endif
However, the potential exists to add -DCA_LITTLE_ENDIAN or
-DEPICS_BIG_ENDIAN to ARCH_DEP_CPPFLAGS as your needs dictate. The benefit
of course being that one need not modify source code in base.
PS: For certain floating point architectures that have the floating point
words in reverse order, in particular ARM net-winder-floating-point if
_ARM_NWFP_ isn't defined, you need to also define EPICS_32107654_FP_ENDIAN.
Jeff
-----Original Message-----
Sent: Monday, August 27, 2007 8:03 AM
To: Peter Zumbruch; Jeff Hill
Subject: Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data
Hi Peter, Jeff,
I had the same problem with little endian Embedded Linux targets, Axis
and others. I wanted the problem solved once and for all without having
to modify the base source code for every new target.
I used 3.14.8, which handles endianess a bit different.
In ca/net_convert.h, I modified the code from
... (known targets)
#else
#       define CA_FLOAT_IEEE
#       define CA_BIG_ENDIAN
#endif
to
#else
#if  !(defined(CA_FLOAT_MIT) || defined(CA_FLOAT_IEEE) )
#endif
#if !(defined(CA_LITTLE_ENDIAN) || defined(CA_BIG_ENDIAN) )
#endif
#endif
This allows to define endianess in my CONFIG.Common.linux-crisv10 file
instead of the source code:
ARCH_DEP_CPPFLAGS += -DCA_LITTLE_ENDIAN
In my opinion, the config files are a much better place to configure the
system than the source code.
The same could be done for 3.14.9 in
libCom/osi/os/default/osdWireFormat.h where we can already read:
// Perhaps the definition of EPICS_BIG_ENDIAN, EPICS_LITTLE_ENDIAN,
// and EPICS_32107654_FP_ENDIAN should be left to the build system
// so that this file need not be modified when adding support for a
// new architecture?
Modify the code to:
... (known targets)
#elif !(defined (EPICS_BIG_ENDIAN) || defined (EPICS_LITTLE_ENDIAN) )
#endif
Dirk
Peter Zumbruch wrote:
> Hello everybody,
> I am working on the port of EPICS to ETRAX CRIS architecture running
Linux.
> We are using several boards which either have Axis's chips:
>    ETRAX LX100 MCM (cris_v10)
>        (http://www.axis.com/techsup/dev/etrax_100lx_mcm/index.htm)
>        or    ETRAX FS (cris_v32)
> as a control unit on-board.
> I meanwhile have succeeded ( :-) ) in compiling EPICS 3.14.9 on a
> linux-x86 host-system for those two architectures:
>    - The CONFIG files needed to be create are documented at:
>        linux-cris_10:
> http://wiki.gsi.de/Epics/ConfigurationEpicsCrossCompileLinuxCrisV10
>        linux-cris_32:
> http://wiki.gsi.de/Epics/ConfigurationEpicsCrossCompileLinuxCrisV32
>    where exclusively linux-cris files have been modified/created.
>    - Changes in CONFIG_SITE.linux-x86.Common:
>        CROSS_COMPILER_TARGET_ARCHS = linux-cris_v10 linux-cris_v32
>    - The cross-compiler used is a gnu-compiler provided by axis:
>        cris-gcc --version: cris-axis-elf-gcc (GCC) 3.2.1 Axis release
> R64/1.64
>    - The file "$EPICS-BASE/src/libCom/osi/default/osdWireFormat.h"
>    has been extended by those two lines to comply for the
> little-endianness :
>     #elif defined (_cris_)
>    - The optimization -O3 had to be replaced by -Os or the default -O0
> to be able to compile.
> Also the example Application created via
>    |$EPICS_BASE/bin/linux-x86/makeBaseApp.pl
> |compiles ||meanwhile without problems.
> Copied to the target system (cris_v10 Target) the IOC starts up
thoroughly.
> "dbl, dbpr, etc" applied to all given records seem to work.
> But,
>    pardon me for the long introduction,
> (either locally or remotely) looking with a client application to the
> the values the data are corrupted:
> using *camonitor* gives for aiExample2
>    (normally having a counter running  from 0 to  9):
> zumbruchHost:aiExample2        2007-08-22 20:08:32.843735 4.33197e-320
> zumbruchHost:aiExample2        2007-08-22 20:08:34.853797 0 ?? ??
> zumbruchHost:aiExample2        2007-08-22 20:08:36.864724 3.03865e-319
> zumbruchHost:aiExample2        2007-08-22 20:08:38.873781 3.16202e-322
> zumbruchHost:aiExample2        2007-08-22 20:08:40.883986 1.04347e-320
> zumbruchHost:aiExample2        2007-08-22 20:08:42.894597 2.05531e-320
> zumbruchHost:aiExample2        2007-08-22 20:08:44.903989 2.56124e-320
> zumbruchHost:aiExample2        1904-10-15 19:11:38.551617 3.06716e-320
> zumbruchHost:aiExample2        2007-08-22 20:08:48.924495 3.57308e-320
> zumbruchHost:aiExample2        2007-08-22 20:08:50.933987 4.07901e-320
> zumbruchHost:aiExample2        2007-08-22 20:08:52.944423 4.33197e-320
> zumbruchHost:aiExample2        1909-01-16 05:53:46.278750 0 ?? ??
> zumbruchHost:aiExample2        1910-02-08 14:34:18.543753 3.03865e-319
> zumbruchHost:aiExample2        1911-03-03 23:14:50.955094 3.16202e-322
> zumbruchHost:aiExample2        2007-08-22 20:09:00.984164 1.04347e-320
> zumbruchHost:aiExample2        1913-04-18 16:35:54.407488 2.05531e-320
> zumbruchHost:aiExample2        1914-05-12 01:16:26.675635 2.56124e-320
> zumbruchHost:aiExample2        2007-08-22 20:09:07.014232 3.06716e-320
> zumbruchHost:aiExample2        2007-08-22 20:09:09.024221 3.57308e-320
> zumbruchHost:aiExample2        2007-08-22 20:09:11.034747 4.07901e-320
> zumbruchHost:aiExample2        2007-08-22 20:09:13.044186 4.33197e-320
> zumbruchHost:aiExample2        1919-09-04 20:39:06.413164 0 ?? ??
> for comparison a similar well running application ("What it should look
> like")
> zumbruch2Host:aiExample2       2007-08-22 20:08:32.613470 1 LOLO MAJOR
> zumbruch2Host:aiExample2       2007-08-22 20:08:34.615208 2 LOLO MAJOR
> zumbruch2Host:aiExample2       2007-08-22 20:08:36.617301 3 LOW MINOR
> zumbruch2Host:aiExample2       2007-08-22 20:08:38.618697 4 LOW MINOR
> zumbruch2Host:aiExample2       2007-08-22 20:08:40.620584 5
> zumbruch2Host:aiExample2       2007-08-22 20:08:42.622103 6 HIGH MINOR
> zumbruch2Host:aiExample2       2007-08-22 20:08:44.623496 7 HIGH MINOR
> zumbruch2Host:aiExample2       2007-08-22 20:08:46.624957 8 HIHI MAJOR
> zumbruch2Host:aiExample2       2007-08-22 20:08:48.627479 9 HIHI MAJOR
> zumbruch2Host:aiExample2       2007-08-22 20:08:50.629924 0 LOLO MAJOR
> zumbruch2Host:aiExample2       2007-08-22 20:08:52.631170 1 LOLO MAJOR
> The same for *ca_test*:
> native type:    DBR_DOUBLE
> native count:   1
> DBR_STRING      3
> DBR_SHORT       768
> DBR_FLOAT       0.0000
> DBR_ENUM        768
> DBR_CHAR        3
> DBR_LONG        50331648
> DBR_DOUBLE      0.0000
> DBR_STS_STRING  1536 256        Value: 3
> DBR_STS_SHORT   1536 256        Value: 768
> DBR_STS_FLOAT   1536 256        Value: 0.0000
> DBR_STS_ENUM    1536 256        Value: 768
> DBR_STS_CHAR    1536 256        Value: 3
> DBR_STS_LONG    1536 256        Value: 50331648
> DBR_STS_DOUBLE  1536 256        Value: 0.0000
> DBR_TIME_STRING 1536 256        TimeStamp: 1901/12/13 21:45:52.547135
> Value: 3
> DBR_TIME_SHORT  1536 256        TimeStamp: 1901/12/13 21:45:52.547135
> Value: 768
> DBR_TIME_FLOAT  1536 256        TimeStamp: 1901/12/13 21:45:52.547135
> Value: 0.0000
> DBR_TIME_ENUM   1536 256        TimeStamp: 1901/12/13 21:45:52.547135
> Value: 768
> DBR_TIME_CHAR   1536 256        TimeStamp: 1901/12/13 21:45:52.547135
> Value: 3
> DBR_TIME_LONG   1536 256        TimeStamp: 1901/12/13 21:45:52.547135
> Value: 50331648
> DBR_TIME_DOUBLE 1536 256        TimeStamp: 1901/12/13 21:45:52.547135
> Value: 0.0000
> DBR_GR_STRING   1536 256        Value: 3
> DBR_GR_SHORT    1536 256 Counts
>            2560        0     2048     1536     1024      512   Value: 768
> DBR_GR_FLOAT    1536 256 Counts   0
>           0.000    0.000    0.000    0.000    0.000    0.000   Value:
> 0.0000
> DBR_GR_ENUM     1536 256        Value: 768
> DBR_GR_CHAR     1536 256 Counts
>              10        0        8        6        4        2   Value: 3
> DBR_GR_LONG     1536 256 Counts
>        167772160        0 134217728 100663296 67108864 33554432
> Value: 50331648
> DBR_GR_DOUBLE   1536 256 Counts   0
> 0.0000
> DBR_CTRL_STRING 1536 256        Value: 3
> DBR_CTRL_SHORT  1536 256 Counts
> 2560        0 Value: 768
> DBR_CTRL_FLOAT  1536 256 Counts   0
>           0.000    0.000    0.000    0.000    0.000    0.000    0.000
> 0.000 Value: 0.0000
> DBR_CTRL_ENUM   1536 256        Value: 768
> DBR_CTRL_CHAR   1536 256 Counts
>              10        0        8        6        4        2
> 10        0 Value:    3
> DBR_CTRL_LONG   1536 256 Counts
> 167772160        0     Value: 50331648
> DBR_CTRL_DOUBLE 1536 256 Counts   0
> 0.000 Value: 0.000000
> DBR_STSACK_STRING       1536 256 256 512 3
> DBR_CLASS_NAME  ai
> and what it should look like:
> native count:   1
> DBR_STRING      3
> DBR_SHORT       3
> DBR_FLOAT       3.0000
> DBR_ENUM        3
> DBR_CHAR        3
> DBR_LONG        3
> DBR_DOUBLE      3.0000
> DBR_STS_STRING   6  1   Value: 3
> DBR_STS_SHORT    6  1   Value: 3
> DBR_STS_FLOAT    6  1   Value: 3.0000
> DBR_STS_ENUM     6  1   Value: 3
> DBR_STS_CHAR     6  1   Value: 3
> DBR_STS_LONG     6  1   Value: 3
> DBR_STS_DOUBLE   6  1   Value: 3.0000
> DBR_TIME_STRING  6  1   TimeStamp: 2007/08/22 20:15:16.962527   Value: 3
> DBR_TIME_SHORT   6  1   TimeStamp: 2007/08/22 20:15:16.962527   Value: 3
> DBR_TIME_FLOAT   6  1   TimeStamp: 2007/08/22 20:15:16.962527   Value:
> 3.0000
> DBR_TIME_ENUM    6  1   TimeStamp: 2007/08/22 20:15:16.962527   Value: 3
> DBR_TIME_CHAR    6  1   TimeStamp: 2007/08/22 20:15:16.962527   Value: 3
> DBR_TIME_LONG    6  1   TimeStamp: 2007/08/22 20:15:16.962527   Value: 3
> DBR_TIME_DOUBLE  6  1   TimeStamp: 2007/08/22 20:15:16.962527   Value:
> 3.0000
> DBR_GR_STRING    6  1   Value: 3
> DBR_GR_SHORT     6  1 Counts
> DBR_GR_FLOAT     6  1 Counts   0
>          10.000    0.000    8.000    6.000    4.000    2.000   Value:
> 3.0000
> DBR_GR_ENUM      6  1   Value: 3
> DBR_GR_CHAR      6  1 Counts
> DBR_GR_LONG      6  1 Counts
> DBR_GR_DOUBLE    6  1 Counts   0
> 3.0000
> DBR_CTRL_STRING  6  1   Value: 3
> DBR_CTRL_SHORT   6  1 Counts
>              10        0        8        6        4        2
> 10        0 Value: 3
> DBR_CTRL_FLOAT   6  1 Counts   0
>          10.000    0.000    8.000    6.000    4.000    2.000   10.000
> 0.000 Value: 3.0000
> DBR_CTRL_ENUM    6  1   Value: 3
> DBR_CTRL_CHAR    6  1 Counts
>              10        0        8        6        4        2
> 10        0 Value:    3
> DBR_CTRL_LONG    6  1 Counts
>              10        0        8        6        4        2
> 10        0 Value: 3
> DBR_CTRL_DOUBLE  6  1 Counts   0
> 0.000 Value: 3.000000
> DBR_STSACK_STRING        6  1  1  2 3
> DBR_CLASS_NAME  ai
> Could somebody give me an advice where else to look at?
> Thanks in advance,
> Peter
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Peter Zumbruch
Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Dirk Zimoch
Prev: RE: PV name changes and epics extensions Rock, Judith E.
Next: RE: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Jeff Hill
Next: Eagle drivers anyone? Heinrich du Toit
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
