Emmanuel
First, IRMIS consists of various parts - PVs, hardware and cabling.
This discussion only concerns the IRMIS PV part.
Emmanuel Mayssat wrote:
IRMIS is definitely one of the solution I am looking for.
But how difficult is it to implement?
You have to install a relational database management system, and then
make the appropriate PERL crawlers work (usually this is an NFS issue:
providing network access for IRMIS to the .db and.dbd files that the
IOC uses to reboot).
It really helps to have a standard ioc build structure, to help the PV
crawler find the associated resource files.
is IRMIS for Oracle databases only?
We use MySQL at APS, SNS and SLAC use Oracle, the Canadian Light Source
uses Microsoft Sequel Server, for example. I think that there is also
some work on PostGreSQL
Are simple crawlers easy to program?
It depends on the domain. The pv crawler is the most complicated since
it is trying to emulate the IOC boot process. In spite of this
complexity, we have had valuable contributions/fixes to the PV crawler
code.
For PV client crawlers, again it depends on how sophisticated the
client handles nested macro substitution, etc
A lot of these crawlers have also been written.
It will be an interesting challenge for the hardware part of IRMIS to
handle the plug-and-play aspects (that you were discussing in another
thread). That is another topic.
Don
is there any other solution out there?
Is anybody on this list at SLAC and using IRMIS?
I definitely would like to have a short demo in the near future.
Emmanuel
On Fri, 2007-08-24 at 14:08 -0500, Don Dohan wrote:
Emmanuel
This is one of the features of the IRMIS relational database.
IRMIS consists of, in part, all of the PVs in your system. A pv crawler
(a perl program) detects when an IOC reboots, then scans and expands
that IOC's st.cmd file to load the IRMIS database with that IOCs PVs.
This scanning is unobtrusive to the IOC.
Other crawlers have been written to scan CA clients. At the APS, we
crawl for MEDM, ALH, and SDDS clients, and we are testing the SNL
crawler written at SLAC. We intend to crawl save/restore files as well
(future). For each CA client instance, a list of resolved PVs is
generated, and inserted into the IRMIS database.
Taking the MEDM client as an example, the crawler resolves the macro
substitutions for nested MEDM screens, so that it tells you which .adl
file in the chain needs to be fixed if a given PV is removed.
Crawlers for other CA clients have been written at other facilities -
EDM, DM/2K for example.
Don Dohan
Another question about software upgrade...
Let's say that I change the name of PV in my epics database.
Potentially with this change, I could break epics extensions.
Medm of course, but also feedback system, PV backup, etc.
Is there a way to know which extensions will break if I change a PV
name? (may keeping track for each extension of the used PVs in a flat
file is the solution, but is there any other, smarter ones?)
Emmanuel
- RE: PV name changes and epics extensions Rock, Judith E.
- PV name changes and epics extensions Emmanuel Mayssat
- Re: PV name changes and epics extensions Don Dohan
- Re: PV name changes and epics extensions Emmanuel Mayssat
Re: bug in Red Hat Linux g++ 3.2.3 Eric Norum
Re: Alarm Handler Janet Anderson
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
