1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: bug in Red Hat Linux g++ 3.2.3
To: Jeff Hill <[email protected]>
Date: Mon, 27 Aug 2007 10:40:50 -0500
On Aug 27, 2007, at 10:34 AM, Jeff Hill wrote:
Hi Dirk,
Ernest indicated that this might be resolved by patching the compiler. If
that is possible then I am disinclined to create a workaround, but if not
then I will see what can be done.
Jeff
-----Original Message-----
Sent: Monday, August 27, 2007 2:36 AM
To: Jeff Hill
Cc: 'EPICS Tech Talk'
Hi
The bug also occurs with -O2, only -O1 is safe.
gcc 3.2.3 is the standard version on Scientific Linux 3, which we still
have in use at the SLS. I would very much appreciate a workaround in the
EPICS code.
Wouldn't a workaround be to just use -O1 for the file(s) where the problem is occurring?
Changing source code to try to deal with compiler problems, especially when the workaround is known, doesn't seem like a very efficient use of resources. Even more so when the compiler in question is getting rather old.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
bug in Red Hat Linux g++ 3.2.3 Jeff Hill
Re: bug in Red Hat Linux g++ 3.2.3 Dirk Zimoch
RE: bug in Red Hat Linux g++ 3.2.3 Jeff Hill
Prev: Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Andrew Johnson
Next: Re: PV name changes and epics extensions Don Dohan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: bug in Red Hat Linux g++ 3.2.3 Jeff Hill
Next: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Peter Zumbruch
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
