Hi Dirk,
Ernest indicated that this might be resolved by patching the compiler. If
that is possible then I am disinclined to create a workaround, but if not
then I will see what can be done.
Jeff
-----Original Message-----
Sent: Monday, August 27, 2007 2:36 AM
To: Jeff Hill
Cc: 'EPICS Tech Talk'
Subject: Re: bug in Red Hat Linux g++ 3.2.3
Hi
The bug also occurs with -O2, only -O1 is safe.
gcc 3.2.3 is the standard version on Scientific Linux 3, which we still
have in use at the SLS. I would very much appreciate a workaround in the
EPICS code.
Dirk
Jeff Hill wrote:
> All,
> There is a bug in Red Hat Linux g++ 3.2.3 when -O3 is specified that
> causes CA R3.14.9 to fail. The bug is known not to occur with several
> other g++ versions, but many versions have not been tested. I also don't
> know what versions of Linux g++ are most commonly used at the various
> EPICS sites.
> So I am curious if this is a substantial issue for the EPICS community
> or if it can be safely ignored? If defective compilers are still in
> widespread use I could look for a workaround in the EPICS source code.
> Jeff
> During testing of R3.14.9 I see a bug showing up only in optimized
> builds on Linux using g++ 3.2.3 that I don't see with other compilers.
> This bug appears to be related to failure of this particular compiler to
> follow the strict alias rules specified in the standard when optimizing
> the byte swapping templates installed for R3.14.9.
> *Problems*
> Red hat Linux g++ 3.2.3 when -O3 is specified
> *No problems*
> mingw g++ 3.4.2 -O3
> Tornado 2.02 g++ -O2
> Microsoft C++ 2005 full optimization builds
> ______________________________________________________
> Jeffrey O. Hill Internet [email protected]
> <mailto:[email protected]>
> LANL MS H820 Voice 505 665 1831
> Los Alamos NM 87545 USA FAX 505 665 5107
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Re: bug in Red Hat Linux g++ 3.2.3 Eric Norum
- bug in Red Hat Linux g++ 3.2.3 Jeff Hill
- Re: bug in Red Hat Linux g++ 3.2.3 Dirk Zimoch
Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Dirk Zimoch
Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Andrew Johnson
<2007>
<2007>
