1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data
To: [email protected]
Date: Thu, 23 Aug 2007 16:20:10 +0200
Hello,
It is now running :-)
Another possibility might be that you need to do a "make rebuild" in order
to force all code to recompile after making the elif defined (_cris_) then
define EPICS_LITTLE_ENDIAN change??
It looks like this has been the (stupid) case, that the application didn't have the right sources available.
Thanks for the help.
I will do some final clean up and checks and will contact Andrew for adding the code to next release.
Peter
Dr. Peter W. Zumbruch EE - department / Controls group / GSI
E-Mail: [email protected] Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
Gesellschaft für Schwerionenforschung mbH Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführer: Professor Dr. Horst Stöcker, Dr. Alexander Kurz
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Peter Zumbruch
Prev: ethernet IP John Sinclair
Next: Job Posting Tom Meyer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data - Optimization issues Peter Zumbruch
Next: Re: Port of EPICS 3.14.9 to ETRAX CRIS architecture - Strange Data Dirk Zimoch
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
