Peter Zumbruch wrote:
Are you sure that this architecture is little-endian? It looks to me from your results below like you should try using EPICS_BIG_ENDIAN. Here's why: name: zumbruchHost:aiExample2 DBR_STRING 3 DBR_SHORT 768 DBR_LONG 50331648 If I convert the short result 768 to hex, the result is 0x0300 instead of 0x0003, i.e. the high and low bytes of the 16 bit result have been swapped from what they should contain. Similarly converting the long result to hex gives 0x03000000 which implies the wrong endianness. Try making that change in osdWireFormat.h and recompiling and I suspect this problem will disappear. Once this is resolved I'll be happy to add this new architecture to the next official release. - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
