1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asyn - interrupts
To: "Heinrich du Toit" <[email protected]>, "Tech-Talk EPICS" <[email protected]>
Date: Tue, 21 Aug 2007 09:09:46 -0500
Hi Heinrich,
You should use the data value that is passed in the callback.  The interrupt callback should never call the read function in the asyn interface directly (it would need to go through queueRequest to ensure that the read runs in the port thread in case the driver is asynchronous, and to ensure correct locking even for synchronous drivers).  In principle it could call queueRequest, and then call read() from the queueRequest callback, but there's really no need to do that.
From: [email protected] on behalf of Heinrich du Toit
Sent: Tue 8/21/2007 8:44 AM
To: Tech-Talk EPICS
Subject: asyn - interrupts
Hi
Just want to make sure about something and what is the general practice
that should be used.
When an interrupt callback is called.
Then there is an parameter to send the "new" data in also.
Ok so when the record support code's interrupt callback is called it
already receive the new data...
But it can obviously still call the read command for the asyn interface
and get the data that way.
So do we assume that the data passed to the interrupt callback is
correct and that no further asyn calls is needed. Or can/should it still
call the read function to get data?
I'm assuming it accepts the data in the callback and go ahead with that
as that would make sense to me.
-Heinrich
RE: asyn - interrupts Heinrich du Toit
Prev: asyn - interrupts Heinrich du Toit
Next: RE: asyn - interrupts Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
