1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: rpath compiling?
To: "Heinrich du Toit" <[email protected]>, "TechTalk EPICS" <[email protected]>
Date: Fri, 17 Aug 2007 17:48:04 +0100
> From: Heinrich du Toit
> It seems that the compile thing sets --rpath in the linker.
> This way it links to a specific directory. Problem is that
> this directory is not the same when built and installed. So I
> would like to have it built without rpath set.
> Then install the .so files to /usr/lib
> And then normal ld.so stuff in linux can link it up.
> My question is - how do I get EPICS to not link to a specific
> directory?
If you use --rpath-link, rather than --rpath, (in RUNTIME_LDFLAGS) then
it will look for the libraries to check them during the link, but not
embed their paths in the resultant executable. Of course, then you need
to have the libraries in the default places or your LD_LIBRARY_PATH on
the target, as I believe Dirk said.
Peter Denison, Senior Software Engineer, Diamond Light Source Ltd.
Tel: +44 1235 778511
(apologies in advance for the lines below. Some bits are a legal
requirement and I have no control over them)
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
rpath compiling? Heinrich du Toit
Prev: Re: Possible Bug in 3.14.9 Access Security on mv2100 Andrew Johnson
Next: RE: Possible Bug in 3.14.9 Access Security on mv2100 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: rpath compiling? Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Next: PI hexapod controller Shepherd, EL (Emma)
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
