You can find the meaning of the EDVR here: http://linux-gpib.sourceforge.net/doc_html/r536.html -1 address is used when asynManager wants to connect to the port driver and connect to gpib card. It searches for gpib card with name defined in first parameter to GpibBoardDriverConfig, in you case L0. You must set name option in gpib.conf file like this: interface { minor = 0 /* board index, minor = 0 uses /dev/gpib0, minor = 1 uses /dev/gpib1, etc. */ board_type = "cbi_isa" /* type of interface board being used */ name = "L0" /* optional name, allows you to get a board descriptor using ibfind() */ pad = 0 /* primary address of interface */ sad = 0 /* secondary address of interface */ timeout = T3s /* timeout for commands */ eos = 0x0a /* EOS Byte, 0xa is newline and 0xd is carriage return */ set-reos = yes /* Terminate read if EOS */ set-bin = no /* Compare EOS 8-bit */ set-xeos = no /* Assert EOI whenever EOS byte is sent */ set-eot = yes /* Assert EOI with last byte on writes */ /* settings for boards that lack plug-n-play capability */ base = 0x310 /* Base io ADDRESS */ irq = 7 /* Interrupt request level */ dma = 0 /* DMA channel (zero disables) */ master = yes /* interface board is system controller */ } Hope this helps. Best Regards Gasper Emmanuel Mayssat wrote: Hello,
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
