Ulrik,
I've looked at the code for devAsynFloat64Array.c and it appears to be
identical to devAsynInt32Array.c, except for obvious differences in the
interfaces. Have you resolved this problem?
Sent: Thursday, July 26, 2007 8:18 AM
To: Pedersen, UK (Ulrik); [email protected]
Cc: [email protected]
Subject: RE: asyn float64array interrupt problem
Hi Ulrik,
It is certainly possible that there is a bug. The support for
interrupt callbacks for waveform records was only added in R4-8. The
Modbus driver is the only one that I am aware of that uses the support,
and it only uses asynInt32Array, not asynFloat64Array. If there is a
problem I suspect it is in devEpics/devAsynFloat64Array. I'll take a
look at that today and see if I can see a problem.
(Ulrik)
Sent: Thu 7/26/2007 4:51 AM
To: [email protected]
Subject: asyn float64array interrupt problem
I have come across a problem with float64Array interrupts when
writing
asyn based driver support for a device. I may just be doing
things wrong
but I have previously got the same thing working for int32,
uint32 and
octet interrupts and I think I'm doing pretty much the same
now...
In the release notes for Asyn version 4-8 it states that
interrupt
support for devAsynFloat64Array has been added (enabling IO
Intr. in
waveform records). Previously I used event processing for the
same
functionality...
So I enabled IO intr in my waveform record:
record(waveform, "$(DAQMX):DATA") {
field(SCAN, "I/O Intr")
field(PINI, "NO")
field(DTYP, "asynFloat64ArrayIn")
field(PREC, "5")
field(INP, "@asyn(myport1 0 5.0)DATA")
field(NELM, "$(NELM)")
field(FTVL, "DOUBLE")
All the asyn registering bits is in the configuration function
and
according to the asyn debug output during startup, the interrupt
gets
2007/07/26 10:34:51.478 drvDaqMxBase::drvUserCreate, attempting
to
create cmd: DATA
2007/07/26 10:34:51.478 drvDaqMxBase::drvUserCreate, command
created:
DATA
2007/07/26 10:34:51.478 test:DATA
devAsynFloat64Array::getIoIntInfo
registering interrupt
2007/07/26 10:34:51.478 myport1 0 registerInterruptUser
In the driver code when I want to execute the interrupt/callback
I do
this:
pasynManager->interruptStart(pPvt->float64ArrayInterruptPvt,
&pclientList);
pNode = (interruptNode *)ellFirst(pclientList);
Here is where the problem occur: pNode is still NULL! So it
seems that
the list of interrupt clients is empty - but according to the
startup
script the devAsynFloat64Array interrupt has been registered for
that
record...(???)
Any idea why this is not working or what I may be doing wrong?
Any
suggestion where I need to start looking for more debug
information?
Cheers,
Ulrik
Ulrik Pedersen phone: +44(0)1235-778580
Software Engineer email:
[email protected]
Diamond Light Source Ltd.
Rutherford Appleton Laboratory,
Chilton, Didcot
OxfordShire OX11 0DE
- RE: asyn float64array interrupt problem Mark Rivers
RE: "invalid UDP request" during boot Laznovsky, Michael
Enabling drvLinuxGpib (linux-gpib) Emmanuel Mayssat
<2007>
RE: asyn float64array interrupt problem Heinrich du Toit
<2007>
