1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PV save and restore tool sought
To: Thomas Birke <[email protected]>
Cc: [email protected]
Date: Tue, 31 Jul 2007 14:54:14 -0700
On Tue, 2007-07-31 at 12:00 -0700, Emmanuel Mayssat wrote:
> * Is log-on-change possible for individual output records? I heard this
> is not the forte of autosave, but I may be wrong.
I meant individual save-on-change or backup-on-change of course.
> I am currently investigating warm reboot.
> As such, I am currently investigating autosave and may move away from
> that feature implementation in the driver.
One could argue that a driver implementation is the best solution
(relative simple to implement + full control). The process function
saves the val in a file with the name of the record. If the file exist,
the init function restores the value (val in db file otherwise).
Sometimes the restored value needs to be fetched from the hardware
itself (or rather an input record). As far as I know, autosave doesn't
do hardware restore. Is there any "high" level utility (outside of
driver/db) that implements that feature?
Note that the streamDevice does that beautifully, but enough rambling
about that driver!
The obvious issue with low level/driver implementation is that it makes
their writing more cluttered and complicated. It also goes against the
trends of having generic high level driver like asyn, devGpib, and ...
stream. But as I said... enough about stream. ;-)
E
PV save and restore tool sought Rock, Judith E.
Re: PV save and restore tool sought Thomas Birke
Re: PV save and restore tool sought Emmanuel Mayssat
Prev: Re: PV save and restore tool sought Eric Norum
Next: Re: PV save and restore tool sought Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: PV save and restore tool sought Tim Mooney
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
