1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: firewire video on RTEMS-4.6.x-MVME5500
To: Sheng Peng <[email protected]>
Cc: [email protected], [email protected]
Date: Mon, 30 Jul 2007 07:42:42 -0400
On  4/10/07 5:28 P.M.   "Sheng Peng"  <[email protected]>wrote:
> Hi Kate,
> Great.
> If I understand this correctly, each of the frame is 6M bits, 30fps means
> 180Mbps. So you are using a dedicate Gigabit Ethernet link, right?
It was actually not a dedicated Ethernet Link.  As what I had responded
to you a few weeks ago, the beatnik BSP that you use for your  video
needs to add the "multiple mbufs" support in its network drivers
to increase its performance.  You are using mvme6100.  Thus, the
performance should be better.
I have implemented the "multi mbufs" for  both of the RTEMS-mvme5500
network drivers (100 MHz and 1GHz) since 2004 as it is published in the
RTEMS4.7.x release and http://www.nsls.bnl.gov/facility/expsys/software/EPICS/.
It is one of the performance boosters I added over the original netBSD
driver.
Hopefully this information will help those who sent me E-mail regarding
their Linux drivers.
> Are you using the edm video widget to plot the image?
Yes.
Kate
> Thanks.
> Sheng
> On 4/10/07 3:02 AM, "Kate Feng" <[email protected]> wrote:
> > Now for a 1024x768x8bit image,  it delivers a TV video
> > effect by achieving 30 Hz simultaneous EPICS real-time
> > display for 30 fps of data transfer.  I showed a  fast-actiom
> > movie on the EPICS display to someone yesterday.  It looked
> > cool. A snapshot of the image sample is at :
> http://www.nsls.bnl.gov/facility/expsys/software/EPICS/[email protected]>
> g
> > A higher throughput is yet to be discovered,  when it is tested
> > on a faster camera.
> > Regards,
> > Kate
Prev: Re: cvt_dbaddr called twice Noboru Yamamoto
Next: Re: dbLoadTemplate in R3.14.9 Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: firewire video on RTEMS-4.6.x-MVME5500 Kate Feng
Next: Re: firewire video on RTEMS-4.6.x-MVME5500 Kate Feng
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
