1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: asyn driver for CMLOG?
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Thu, 26 Jul 2007 22:29:44 -1000 (HST)
don't know about CMLOG, but in the channel archiver you just
set the record to monitor.
How often you log or archive things ought to be set up in
the logger/archiver. It shouldn't have anything to do with
how a record processes (at face value. Of course if you monitor
a record it will).
We still have almost brute force cau cron jobs running that just
log and plot (don't try this on a network that has a B300 on it
unless you're really sure about your network masking and such -
of course nobody but us has B300s)
Aloha,
Maren
On Fri, 27 Jul 2007, Heinrich du Toit wrote:
Hi
I guess CMLOG is the logging system of choice? Or is there something
else I should look at?
Anyways I was wondering If there is somewhere some sort of device
support (maybe asyn) so that you can maybe link a stringout record to
the logger or something like that.
I guess most common thing you want is to have a seq program to output to
the logger? How should I do this?
Thankyou
-Heinrich
Re: asyn driver for CMLOG? Heinrich du Toit
Prev: Re: stream/asyn devices Dirk Zimoch
Next: Re: asyn driver for CMLOG? Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: asyn driver for CMLOG? Heinrich du Toit
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
