1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: IPac driver organisation
To: Doug Murray <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Tue, 17 Jul 2007 17:19:09 -0500
Hi Doug,
Doug Murray wrote:
Hi Andrew, Iâve noticed the IPac directory contains support for a number of carrier cards. Would it be possible to add drivers for:
xycom9660
acromag9670
hytec8002
We use these at SLAC, and weâre using RTEMS so weâve had to OSI-ify these packages.
Andy Foster wrote the Xycom/Acromag carrier driver which is licensed like the rest of Ipac under the LGPL (currently V2.1; I may move Ipac to V3 before the next release). If Andy is happy for it to be included I'm willing to add it (with a few minor changes) to the Ipac distribution. The next release of Ipac already uses the OSI interfaces for everything except the tyGSOctal driver and ATC-40 carrier driver, so I'd want an OSIfied version rather than the vxWorks only code that is in his xycomIpac-1.0 release. If you have an OSIfied version, please send me a copy.
The Hytec driver is Copyright Hytec, and the source code we have here does not mention any licensing terms at all, so I can't distribute it anyway. I would not be willing to maintain this code at present, which also provides some VME64X hot swap capabilities that I do not claim to comprehend.
Also, I see drivers for a few IP cards in that directory, such as CANbus and an Octal UART card. Is the idea that new IP drivers be placed in this directory as well?
No; those module drivers are only still there because I maintain them and I haven't been sufficiently motivated yet to remove them to their own support module(s). I don't want to add other IP module drivers to drvIpac because I don't want to take ownership of anyone else's code.
The EPICS build system is designed to make modules easy to create and use; just glomming a whole lot of unrelated drivers together into a single support module makes maintenance take longer and discourages people from releasing new versions of the resulting mess (the private 'share' module at APS for an excellent example of that particular nightmare - 7 record types and 29 device supports that nobody wants to own or touch if they can avoid it).
On a related note, the GPIB IP card (IP488) is located in the Asyn directory. Should IP modules be put under Asyn?
Since that card is supported by the devGpib subsystem which is currently a part of Asyn, I think that is the appropriate place for it.
IP module drivers should be released either individually or in small groups of related drivers, making it as easy to put together the software for an IP-based IOC as it is for the hardware.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
RE: IPac driver organisation Denison, PN (Peter)
IPac driver organisation Doug Murray
Prev: Re: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
Next: Re: MEDM enum not displaying correctly? Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: IPac driver organisation Doug Murray
Next: RE: IPac driver organisation Denison, PN (Peter)
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
