The Application Developer's Guide does not explain the difference
between asyn_LIBS and asyn_SYS_LIBS, except for the order in which they
are passed to the linker. What is the difference? I have always used
SYS_LIBS for libraries that are not in the EPICS directories. I think
one difference is that when building a static application that shareable
versions of SYS_LIBS are still used, while all non SYS_LIBS libraries
are statically built into the binary, right? Is this documented
anywhere?
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Tuesday, July 17, 2007 10:49 AM
> To: Mark Rivers
> Cc: Jiro Fujita; EPICS tech-talk
> Subject: Re: RE: Asyn 4.8 compile error with Linux GPIB
> Hi Mark,
> > The line
> > asyn_LIBS += gpib
> > tells the EPICS build system to look for libgpib.a in the EPICS
> > directories. This does not seem to be correct, that is a system
> > library, not an EPICS library. So I think that line should be
> No, setting asyn_LIBS like that tells the build system to
> link the asyn binary with libgpib (it results in the link
> line having -lgpib added to it). If libgpib is not being
> found you can explicitly tell the build system where it is by
> setting the gpib_DIR variable in the Makefile. Alternatively
> and more generally you can tell the linker to look in
> /usr/local/lib automatically by listing that directory in
> /etc/ld.so.conf or by creating a file in /etc/ld.so.com.d
> with the appropriate setting.
> > Note, I think that LD_LIBRARY_PATH is used only at run-time to find
> > .so files, not when building applications, so I would not expect it
> > to work.
> Sorry, but you're wrong there too; having LD_LIBRARY_PATH set
> at build-time is actually frowned upon nowadays because if
> it's set at link time its value will be saved in the binary
> and the path re-used at runtime, which is contrary to how
> most Linux package management systems like to work (they
> build in a different location to their final runtime
> location, so their link-time paths will not be valid at runtime).
> > I don't think you have explained how libgpib.a got in the asyn
> > tree, if it really is there.
> I agree, I think that file should be deleted.
> - Andrew
- Re: Asyn 4.8 compile error with Linux GPIB Janet Anderson
- Re: RE: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
IPac driver organisation Doug Murray
<2007>
<2007>
