1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ASLO / AOFF scaling for ai and ao record
To: EPICS tech talk <[email protected]>
Date: Fri, 13 Jul 2007 23:27:40 +0200
Tim,
On Freitag, 13. Juli 2007, you wrote:
> Stefan Heim wrote:
> > In the streamdevice protocol file I have (among others)
> > getX {
> >         out "Joe Crds ?";
> >         in "Joe Crds %f %*f %*f %*f %*f %*f %*f ";
> > setX {
> >         out "Joe AxisAbs 1 %(VAL)f";
> >         in "Joe started";
> I think you are *telling* the streamDevice to ignore ASLO and AOFF, by
> using the
> format "%(VAL)f".
That's indeed the case. It's a feature, not a bug ;-) If I use %f instead
of %(VAL)f, I get the desired ASLO/AOFF scaling with streamdevice and an ao
record.
> As I read the doc, it would do what you want if you
> used the
> format "%f".  According to streamDevice/doc/ao.html, the streamDevice
> would, in this case, perform the calculation
>     |OUTPUT_VALUE = (OVAL-AOFF)/ASLO
> without converting to integer.  (I.e., the streamDevice would grab the
> required
> field values, and perform the calculation independently of the record.)
Can't believe this has slipped through my attention! Stupid mistake, thank you
for getting me back on track.
On a academic basis I still wonder whether to give the responsibility to
honour ASLO/AOFF to the device support is a good idea. Aren't ASLO/AOFF
supposed to be a property of _any_ ao record, regardless what device support
it might reside on?
Thanks again,
-Stefan
Stefan Heim, PhD Student X-ray microscopy
BESSY mbH, Albert-Einstein-StraÃe 15, D-12489 Berlin, Germany
voice: +49 30 6392 3177 fax: + 49 30 6392 4757 e-mail: [email protected]
BESSY mbH - Mitglied der Leibniz Gemeinschaft
Vorsitzender des Aufsichtsrates: Prof. Dr. Dr. h.c. mult. Joachim Treusch
GeschÃftsfÃhrer: Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Prof. Dr. Eberhard
Jaeschke
Sitz Berlin, AG Charlottenburg, HRB 14635
Re: ASLO / AOFF scaling for ai and ao record Tim Mooney
ASLO / AOFF scaling for ai and ao record Stefan Heim
Prev: Re: Scan question John Sinclair
Next: Re: ASLO / AOFF scaling for ai and ao record Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ASLO / AOFF scaling for ai and ao record Tim Mooney
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
