Hello all,
I have a device that came with a controller from the vendor. This controller
offers a TCP/IP server you can connect to and send a certain set of commands
to operate the device.
Using EPICS, asyn and streamdevice, it has been close to trivial to set up a
basic softIOC to operate the device (essentially a getPosition/setPosition
operation).
In the streamdevice protocol file I have (among others)
getX {
out "Joe Crds ?";
in "Joe Crds %f %*f %*f %*f %*f %*f %*f ";
setX {
out "Joe AxisAbs 1 %(VAL)f";
in "Joe started";
In the database I have (among others)
record (ai, "MyIOC:X")
field (SCAN, ".1 second")
field (DTYP, "stream")
field (INP, "@device.proto getX MYPORT")
# EGU, HOPR, LOPR, PREC, warning limits, ... left out for brevity
record (ao, "MyIOC:setX")
field (SCAN, "Passive")
field (INP, "@device.proto setX MYPORT")
# EGU, DRVL, DRVH, PREC, warning limits, ... left out for brevity
This works like a charm, I can do "caget MyIOC:X" to get the current position
and "caput MyIOC:setX <targetpos>" to drive to a target position.
Now I want these records to operate in different, linearly transformed
coordinates rather than in the device's very own coordinates, let's say for
example
myCoords = -20.5 * devCoords + 5.3 .
Therefore, I added
field (ASLO, "-20.5")
field (AOFF, "5.3")
to the ai and ao records described above; for the ai record, this had the
desired effect, i.e. the record now delivers the position in transformed
coordinates.
However, the ao record _ignores_ ASLO and AOFF with a streamdevice device
support. Is this the intended behaviour? Or a bug in streamdevice's device
support for the ao record?
How are you supposed to solve the problem of linear coordinate transformations
without adding a bunch of helper records (calc & calcout, or even motor) to
the database?
The LINR="Slope" ESLO/EOFF scaling of the ao record would be sufficient, if
only RVAL was a double rather than a long; atm if you use it, it
truncates "devices coordinates" to whole numbers after doing the correct
transformation.
Any suggestions?
-Stefan
Stefan Heim, PhD Student X-ray microscopy
BESSY mbH, Albert-Einstein-StraÃe 15, D-12489 Berlin, Germany
voice: +49 30 6392 3177 fax: + 49 30 6392 4757 e-mail: [email protected]
BESSY mbH - Mitglied der Leibniz Gemeinschaft
Vorsitzender des Aufsichtsrates: Prof. Dr. Dr. h.c. mult. Joachim Treusch
GeschÃftsfÃhrer: Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Prof. Dr. Eberhard
Jaeschke
Sitz Berlin, AG Charlottenburg, HRB 14635
- Re: ASLO / AOFF scaling for ai and ao record Stefan Heim
- Re: ASLO / AOFF scaling for ai and ao record Tim Mooney
Re: Scan question John Faucett
<2007>
Re: Scan question Emmanuel Mayssat
<2007>
