1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: trouble with custom record
To: "Heinrich du Toit" <[email protected]>, "TechTalk EPICS" <[email protected]>
Date: Fri, 6 Jul 2007 08:00:37 -0500
You are missing something with the dbd files or Makefile.
Here's how I normally do it.  In the module that defines the record (in this case the mca record in the mca module) create a file called mcaSupport.dbd that includes mcaRecord.dbd:
corvette> more mcaSupport.dbd
# RECORD SUPPORT
include "mcaRecord.dbd"
In the module that will use the record (in this case the same module) in the appInclude.dbd file, include mcaSupport.dbd:
corvette> more mcaInclude.dbd
include "base.dbd"
include "mcaSupport.dbd"
In your Makefile you need lines like these:
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += mcaRecord
# <name>.dbd will be created from <name>Include.dbd
DBD += mca.dbd
DBD += mcaSupport.dbd
LIBRARY_IOC += mca
mca_SRCS += mcaRecord.c
mca_LIBS += $(EPICS_BASE_IOC_LIBS)
From: [email protected] on behalf of Heinrich du Toit
Sent: Fri 7/6/2007 3:45 AM
To: TechTalk EPICS
Subject: trouble with custom record
Ok so I read all the stuff on custom records.. And I think I understand
the programming part and how the functions should get called ect ect.
But I can't seem to get the things to compile?
I have myRecord.dbd with record def inside. dbToRecordH thingy works
I have myRecord.c with the code. It can compile fine.
But I can't seem to get this to load into the actual ioc.
When I try to DBLoadDataBase(myRecord.dbd) then it complains about
dbCommon.dbd not available.
If I try to load myRecord.dbd as part of my ioc.dbd with the makefile
the I get some error in ioc_registerRecordDeviceDriver.cpp
if I try to get it to "expand" a new .dbd for my record it complains
about menu stuff missing.
help?
Re: trouble with custom record Ned D. Arnold
trouble with custom record Heinrich du Toit
Prev: trouble with custom record Heinrich du Toit
Next: Re: trouble with custom record Ned D. Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
