hello,
I can not configure labview to get information from BINP, but i am still
trying. But I can use TINP to take the points step by step, but it
requires a lot of time since its size is limited to 40 bytes andI have
to take 2500 points. This size is set by epics base, isn't it? Does
anybody know if is possible to change this value to a higher one? I have
been looking in the code but i don't find any clue.
many thanks
Mikel
I suspect the problem is with Labview, not with asynRecord, since BINP works OK in other applications.
I don't know the Labview interface. You need to make sure that it is trying to read a char array for BINP, not an EPICS string PV.
From: [email protected] on behalf of Mikel Eguiraun
Sent: Tue 6/26/2007 5:46 AM
To: [email protected]
Subject: asynRecord and Labview problem
hello,
I have an epics server publishing information from an osciloscope using
asynRecord, and i want to take this information using Labview (8.5b). I
have problem reading BINP field of asynrecord to take the points of the
scope's screen (the rest of the fields are ok), i get the following
error in Labview:
"Warning -1950679034 occurred at Shared Variable Read in server.vi
Possible reason(s):
LabVIEW: (Hex 0x8BBB0006) The shared variable has no value.
This warning occurred while reading \\My Computer\server\Variable1
(\\192.168.0.5\server\Variable1)"
but if I use the command shell i am able to take those points. I am new
to epics and labview, so i don't know in which side the problem is, has
anybody have any suggestion to fix this problem?
many thanks in advance
Mikel Eguiraun
- RE: asynRecord and Labview problem Mark Rivers
- asynRecord and Labview problem Mikel Eguiraun
Re: PV save and restore tool sought Andrew Johnson
Re: medm, edm, other on fc6 Guy Jennings
<2007>
<2007>
