medm cannot compile with lesstif on FC6. You will need both
openmotif-2.3.0-0.1.9.3.i386.rpm and
openmotif-devel-2.3.0-0.1.9.3.i386.rpm
I would also recommend uninstalling lesstif-devel because
openmotif-devel uses the same filenames and can lead to confusion. Only
the machine used to compile medm will need the openmotif-devel package.
Emmanuel Mayssat wrote:
Hello,
I am having a few difficulties compiling medm specifically on fedora
core 6. First I had to install the lesstif-devel to get missing header
files, then I change my CONFIG_SITE.linux-x86.linux86 and customize it
to my platform, then when I compile and I get conflicting definition for
_XmDrawShadow which is declared as extern in /usr/include/Xm/XmDraw.h
and in .../medm/xc/Matrix.c. As a result, Matrix.c doesn't compile.
Bummer! Has anyone experienced this problem?
I tried to compile edm in place of medm.
Again I hit roadblocks on fc6.
I did not investigate the reason in depth.
But is there anything that I can use to visualize me PV on fc6 (i.e.
that is straight forward to compile) ?
I also remember reading a thread related to Motif support in future
linux versions. If I remember correctly motif was not going to be
supported any more. Is that true?
E
- medm, edm, other on fc6 Emmanuel Mayssat
RE: medm, edm, other on fc6 Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
RE: medm, edm, other on fc6 Hammonds, John P.
<2007>
Re: medm, edm, other on fc6 Guy Jennings
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
