Title: RE: medm, edm, other on fc6
Emamanuel,
Are you missing openmotif? Fedora Core 6 removed openmotif, and does not include it. Fedora Core 5 was supposed to be the last Fedora openmotif.
I took openmotif from Fedora Core 5 and used "rpm" to install "openmotif-2.3.0-0.1.9.2.i386.rpm" which is all that should be needed. I also installed "openmotif-devel-2.3.0-0.1.9.2.i386.rpm" although it should not be needed.
An alternative would be to get openmotif.xxxxx.tar.gz and compile and install it, if your prefer.
Billy R. Adams
757-864-5934
-----Original Message-----
From: [email protected] on behalf of Emmanuel Mayssat
Sent: Wed 06/27/07 4:28 PM
To: [email protected]
Subject: medm, edm, other on fc6
Hello,
I am having a few difficulties compiling medm specifically on fedora
core 6. First I had to install the lesstif-devel to get missing header
files, then I change my CONFIG_SITE.linux-x86.linux86 and customize it
to my platform, then when I compile and I get conflicting definition for
_XmDrawShadow which is declared as extern in /usr/include/Xm/XmDraw.h
and in .../medm/xc/Matrix.c. As a result, Matrix.c doesn't compile.
Bummer! Has anyone experienced this problem?
I tried to compile edm in place of medm.
Again I hit roadblocks on fc6.
I did not investigate the reason in depth.
But is there anything that I can use to visualize me PV on fc6 (i.e.
that is straight forward to compile) ?
I also remember reading a thread related to Motif support in future
linux versions. If I remember correctly motif was not going to be
supported any more. Is that true?
E
- RE: medm, edm, other on fc6 Hammonds, John P.
- medm, edm, other on fc6 Emmanuel Mayssat
Re: medm, edm, other on fc6 Bob Soliday
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
