1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asynRecord SEGFAULT?
To: "Heinrich du Toit" <[email protected]>, "TechTalk EPICS" <[email protected]>
Date: Tue, 19 Jun 2007 06:43:32 -0500
Before running medm on the asyn record, at the ioc prompt you could do:
dbpr "myAsynRecord",5
That might help find the problem.
From: [email protected] on behalf of Heinrich du Toit
Sent: Tue 6/19/2007 5:44 AM
To: TechTalk EPICS
Subject: asynRecord SEGFAULT?
Hi
I've started experimenting with asyn.
Now I've created the routines for a driver with Common and devInt32
interfaces.
When I connected my own record (ai) 2 this to read it works fine.
Then I tried connecting a asynRecord to this.
It starts up fine.
But when I run medm to see this record the IOC segfaults.
plockRecord->plockSet
because plockSet = null
and this is because precord->lst = null
And that must be the lockRecord or something.
I don't understand, the stack trace doesn't even run through asyn or my
own code.
I have no idea where to look for the fault :(
-Heinrich
asynRecord SEGFAULT? Heinrich du Toit
Prev: Re: asynRecord SEGFAULT? Eric Norum
Next: RE: asynRecord SEGFAULT? Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
