1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: VxWorks Buffer Problems
To: "'Matt Rippa'" <[email protected]>, <[email protected]>
Date: Wed, 13 Jun 2007 10:11:30 -0600
Matt,
> CA.Client.Diagnostic...........................................
>    Message: "Network connection lost"
>    Severity: "Warning" Context: "10.2.2.104:5064"
>    Source File: ../iocinf.c Line Number: 1488
> CAC: unexpected select fail: 851971=S_iosLib_INVALID_FILE_DESCRIPTOR
As I recall there was a benign message like that in R3.13 that resulted from
blocking in select() at the same time that a file descriptor select was
watching was closed.
>0x820dec (CA_event): CAS: TCP send to "10.2.2.63:55102"
> failed because "S_errno_ENOBUFS"
>From my perspective this isn't a crash but instead a diagnostic, but I can
understand that the net result is the same - communication is lost. You
might fault isolate by checking to see if the IOC is ping-able, and or
responding to telnet, during this situation.
Are the mbuf messages occurring only with the MVME-2700 hardware? If so I
would make certain that you have all of the driver patches from wrs.
> When I run 'netStackSysPoolShow' I see 2048 mbufs
As I recall on vxWorks the ENOBUF error number can be returned when running
out of, in addition to mbufs, clusters of various sizes, and also driver
buffers.
They have some experience with vxWorks buffer starvation issues and PPC VME
cards at the SNS. Dave Thompson there might have some advice.
Also, EPICS R3.14.7 or higher ca client library is better optimized to avoid
increasing traffic during isolated periods of network congestion compared to
previous versions. One way to ease into R3.14 would be to try linking your
console applications with R3.14 first.
Jeff
-----Original Message-----
On Behalf Of Matt Rippa
Sent: Tuesday, June 12, 2007 7:45 PM
To: [email protected]
Subject: VxWorks Buffer Problems
Hi All -
Lately we have several CA crashes which may be buffer problems on
our IOC's. We're using EPICS R3.13.4 on MVME-167 and MVME-2700
targets.
When I run 'netStackSysPoolShow' I see 2048 mbufs. This looks
good to me. Are there other useful checks from the shell I can
run to assert my image is built in the best manner possible?
The INVALID FILE DESCRIPTOR message below seems strange to me.
Has anyone seen that before?
Thanks for any help,
-Matt Rippa
 > dbCa:exceptionCallback stat Network connection lost channel
unknown
unknown
 > 0x93f7f4 (CA_event): CAS: TCP send to "10.2.2.151:59106"
 >0x820dec (CA_event): CAS: TCP send to "10.2.2.63:55102" failed
 >0x7d47e8 (CA_event): CAS: TCP send to "10.1.10.18:37796" failed
 >0x8408b4 (CA_event): CAS: TCP send to "10.1.5.50:56530" failed
 >0x845558 (CA_event): CAS: TCP send to "10.2.2.55:46467" failed
 >0x81b4ac (CA_event): CAS: TCP send to "10.2.2.31:41488" failed
because "S_errno_ENOBUFSCAC: erro"
 >r = "S_errno_ENOBU0xFS" sending UDP ms819f0cg to 10.2.2.255 (:5064
 >CA_event): CAS: TCP send to "10.2.2.31:41489" failed because
"S_errno_ENOBUFS"
 >0x8abe64 (CA_event): CAS: TCP send to "10.2.5.43:44426" failed
VxWorks Buffer Problems Matt Rippa
Prev: Sr Technical Offer for CODAC - ITER Opening Adams, Paul F.
Next: Libera EPICS driver -- version 1.40.2 Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: VxWorks Buffer Problems Matt Rippa
Next: IOC options Heinrich du Toit
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
