Mark Rivers wrote:
The reason I'm asking is that in my application, only the
channel access
link causes "answr" to process, the database link doesn't, and we
couldn't agree on what was supposed to happen.
That is what is supposed to happen. If you want a record to process
when its input changes then you must set the link to CP.
PP is what you set output links to if you want it to process the record
that the output is linked to.
Of course you can use PP on input links, too:
it causes the record that the link points to to process before the data
is read from the link.
In your example:
if "b.VAL" changes then the record "answr" processes and this in turn
causes record "a" to process,
before "a.VAL" is read to "answr.B" and "answr.VAL" is calculated.
For further information read the "Record Reference Manual", Chapter
"1.3. Passive Scanning",
e.g. at
http://www.aps.anl.gov/epics/EpicsDocumentation/AppDevManuals/RecordRef/Recordref-1.html
Cheers
Andreas
-----Original Message-----
[mailto:[email protected]] On Behalf Of Mathias Steiner
Sent: Tuesday, June 12, 2007 6:00 PM
To: [email protected]
Subject: Basic Question regarding input links
Learned Friends,
I have what I believe to be a very basic EPICS question.
I'm new to ioc programming, so bear with me, please.
Let "a" and "b" be analog input records, passive, initialized to 1.
On the same ioc as those two, define
record(calc, "answr")
field(INPA, "a.VAL PP NMS")
field(INPB, "b.VAL CP NMS")
field(CALC, "A+B")
As the ioc starts up, the value of "answr" is 2, as expected.
My question is this:
When "a" is set to another value, does "answr" process?
Also, when "b" is set to a different value, does "answr" process?
In other words, does a change in the linked record lead to
processing of
the linking record, and does it do so for both database links and
channel access links?
channel access
Cheers, and Thanks in advance,
-Mathias
Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002
[email protected], http://people.web.psi.ch/luedeke
- Re: Basic Question regarding input links Benjamin Franksen
- RE: Basic Question regarding input links Mark Rivers
VxWorks Buffer Problems Matt Rippa
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
