a new version of StreamDevice is now released. Upgrade is recommended especially if you are running a CVS-snapshot version. (If you have already found version 2.2 and downloaded it before 4th of June, download again. That version was buggy.) The new version includes several bugfixes and new features since 2.1 (some of them were already included in patches or the snapshot versions): Bugfixes: Deadlock in exec command Problems with Terminator="" Waveform read bug Registration problems in vxWorks and cygwin @mismatch handler missing Crashes in streamReload and other places asynOverflow problem with GPIB "I/O Intr" problems Features: %(FIELD) and $(record.FIELD) redirection syntax aai and aao support connect / disconenct commands Use terminators defined by asynDriver as default Support for base R3.13.7+ on vxWorks Patches for base R3.14.9 and gcc 4.1.1 Support of Windows and RTEMS Download: http://epics.web.psi.ch/software/streamdevice/ Dirk
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
