1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CA client on unix bug
To: TECHTALK tech-talk <[email protected]>
Date: Sun, 10 Jun 2007 12:37:55 -0700
I found the following problem (tested on
linux, solaris, base-3.14.9, base-3.14.8.2)
with the CA client on unix:
Scenario:
IF
 - no caRepeater is running
 - CA client tries to fork a caRepeater
   but the 'exec' syscall fails (e.g., because the
   caRepeater is not found in PATH)
THEN
the forked process may end up blocking
for an event that never happens and hence
may never exit (see attached test program for
more details) and therefore never release system
resources.
FIX: libCom/osi/os/posix/osdProcess.c:osiSpawnDetachedProcess()
 should call _exit() rather than exit() if execle() fails.
REPRODUCE: try attached code (comments contain analysis
of the problem).
-- Till
#include <cadef.h>
#include <errlog.h>
#include <epicsThread.h>
/* Test program to demonstrate a problem with the CA client
 * (base-3.14.8.2 and maybe earlier, base-3.14.9):
 * 1) make sure no caRepeater is running
 * 2) make sure no caRepeater is found in the PATH
 * 3) make sure no other instance of this program is running
 *    the ouput of 'ps' may look like this:
 *    tillbook:~/test> ps
 *            PID TTY          TIME CMD
 *          29357 pts/1    00:00:00 tcsh
 *           1753 pts/1    00:00:00 ps
 * 4) execute this program; the message
 * **** The executable "caRepeater" couldn't be located
 * **** because of errno = "No such file or directory".
 * **** You may need to modify your PATH environment variable.
 * **** Unable to start "CA Repeater" process.
 * should be printed to the console.
 * 5) after termination, check for more instances of this
 *    process. There should be one hangning around. Check
 *    the output of 'ps':
 *            PID TTY          TIME CMD
 *           1834 pts/1    00:00:00 ca_zombie_tst  <<<< leftover process
 *           1835 pts/1    00:00:00 ps
int main(int argc, char**argv)
chid cid;
ca_context_create(ca_enable_preemptive_callback);
/* errlogInit spawns a thread 'errlog' */
errlogInit(0);
/* suspend for some time so that the errlog thread can
 * run, register an epicsAtExit handler and block for work
epicsThreadSleep(.5);
/* ca_create_channel forks and tries to exec the caRepeater.
 * If the 'exec' syscall fails then the forked process
 * calls 'exit()' which ends up calling epicsExitCallAtExits().
 * The errlog exit handler sends the errlog thread a
 * 'termination request' event and blocks for the errlog thread
 * to terminate. However, the 'fork'ed process doesn't inherit
 * threads and therefore the exit handler blocks forever since
 * it will never receive the 'errlog termination done' event
 * because there is no errlog thread in the forked process.
 * Thus, the forked process is stuck and will never exit.
 * IMO, the forked process should _exit rather than exit
 * if exec("caRepeater") fails.
ca_create_channel("dummy_nonexisting_PV",0,0,0,&cid);
ca_pend_io(1.0);
ca_clear_channel(cid);
ca_context_destroy();
return 0;
Re: CA client on unix bug Andrew Johnson
RE: CA client on unix bug Jeff Hill
Prev: Re: Unexplained .db performance issues Geoff Savage
Next: GigE Vision-compliant cameras Malitsky, Nikolay D
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: CA client on unix bug Andrew Johnson
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
