I do something very similar but with a nx server/client architecture.
Have a look at freenx and nxclient (nomachine.com)
The idea is that you do not forward the PV directly, but a display with
the values of the PV. The nx protocol is TCP based, use ssl encryption
(over ssh), and use compression.
With a gateway over the internet, you will probably lose most of your
UDP datagrams anyway, plus there is the network latency, etc.
I heard that a secure epics gateway is being developed though.
How far are you from the IOCs ?
Emmanuel Mayssat
On Fri, 2007-06-08 at 15:09 -0400, J. Lewis Muir wrote:
> Doug Sheffer wrote:
> > Hello!
> > I was wondering if anyone has experimented and had good luck with
> > accessing real-time EPICS channel data over the Internet. Is this, by
> > any chance, something that is possible with the EPICS gateway?
> > Since allowing access over the Internet in any way would inevitably be
> > a large security risk, we would like to be able to use SSH tunneling
> > to secure the connection and to monitor who is doing what with the
> > system. Unfortunately, SSH seems unsuitable because it only supports
> > tunneling on TCP ports, while EPICS uses both TCP and UDP.
> > Has anyone done anything similar, or got any ideas/suggestions on how
> > to go about doing it securely?
> > Your help is much appreciated.
> > Doug Sheffer
> You could use a VPN. It depends on what you want to do. Or maybe you
> have constraints that make this not an option?
> -lewis
- Re: EPICS channels via the Internet Doug Sheffer
- EPICS channels via the Internet Doug Sheffer
- Re: EPICS channels via the Internet J. Lewis Muir
<2007>
<2007>
