Carl Susanna Jacobson wrote: Does anyone have a script or program that will take a set of C function declarations and generate the C code to register those functions with the iocsh? -- Carl Lionberger 510 486 7503 Software Developer, Engineering Division Lawrence Berkeley National Laboratory #!/usr/bin/perl # # makeRegistrar # # Takes [ansi vanilla] function prototypes and produces EPICS registrar # function. # # output is to be inserted into code containing functions to be registered. # Note the registrar function and its export call both use the program name # "xxx", which you need to change by hand. # # be sure to include "iocsh.h" and "epicsExport.h" in the file. # # Example prototypes from autoSaveRestore: # # Clip these and use as test input if desired. Remove the ^# # #int set_savefile_name(char *filename, char *save_filename); #int create_periodic_set(char *filename, int period, char *macrostring); #int create_triggered_set(char *filename, char *trigger_channel, # char *macrostring); #int create_monitor_set(char *filename, int period, char *macrostring); #int create_manual_set(char *filename, char *macrostring); #int fdbrestore(char *filename); #void fdblist(int verbose); # #int set_requestfile_path(char *path, char *pathsub); #int set_savefile_path(char *path, char *pathsub); #int set_saveTask_priority(int priority); #int remove_data_set(char *filename); #int reload_periodic_set(char *filename, int period, char *macrostring); #int reload_triggered_set(char *filename, char *trigger_channel, # char *macrostring); #int reload_monitor_set(char * filename, int period, char *macrostring); #int reload_manual_set(char * filename, char *macrostring); #int fdbrestoreX(char *filename); # # # input # $i = 0; while (<>) { # chomp(); @inlist[$i] = $_; $i++; } # # combine broken lines # $i = 0;$untermed=0; foreach (@inlist) { if (!/;$/) { chomp; @outlist[$i] = $_; $untermed = 1; } else { if ($untermed == 1) { $untermed = 0; @outlist[$i] = join("",@outlist[$i],$_); } else { @outlist[$i] = $_; } $i++; } } #print @outlist; #get args $i = 0; foreach (@outlist) { ($junk, $arglist) = split("[(]",$_); ($arglist, $junk) = split("[)]",$arglist); @allargs[$i] = $arglist . "\n"; $i++; } # # produce argument descriptors, arg lists, funcdefs, callfuncs # $i = 0; $funcfound = 0; foreach (@allargs) { # # note that is block of code is repeated below, to catch last # member of list. # if ($funcfound == 1) { $funcfound = 0; print "static const iocshArg * const ".$funcname."Args\[" . $j ."\] = {\n"; for ($k = 0; $k < $j; $k++) { print " &" . $funcname . "Arg" . $k; if (($k + 1) < $j) { print ",\n"; } else { print "\};\n"} } print "static const iocshFuncDef " . $funcname . "FuncDef = {"; print "\"". $funcname ."\"," . $j . "\," . $funcname."Args};\n"; print "static void " . $funcname . "CallFunc\(const iocshArgBuf *args)\n"; print "{\n"; print " " . $funcname . "\("; for ($k = 0; $k < $j; $k++) { print "args\[" . $k . "\]\."; if (@types[$k] eq "iocshArgInt") { print "ival"; } if (@types[$k] eq "iocshArgString") { print "sval"; } if (@types[$k] eq "iocshArgDouble") { print "dval"; } if (($k + 1) < $j) { print ","; } else { print "\);\n"} } print "}\n"; } ($type, $funcname) = split(/\s+/,@outlist[$i]); ($funcname, $junk) = split(/\(/,$funcname); $i++; @names = ""; @types = ""; $j = 0; @args = split; $typefound = 0; $charfound = 0; foreach (@args) { if ($charfound == 2) { $charfound = 0; @types[$j] = "iocshArgString"; if (/,$/) { chop($_); } @names[$j] = $_; $funcfound = 1; print "static const iocshArg " . $funcname . "Arg" . $j . " = { "; print "\"". @names[$j] . "\",". @types[$j] . " };\n"; $j++; next; } if ($charfound == 1 && /\*/ && length($_) == 1) { $charfound = 2; next; } if ($charfound == 1 && /\*/ ) { s/\*//; $charfound = 0; @types[$j] = "iocshArgString"; if (/,$/) { chop($_); } @names[$j] = $_; $funcfound = 1; print "static const iocshArg " . $funcname . "Arg" . $j . " = { "; print "\"". @names[$j] . "\",". @types[$j] . " };\n"; $j++; next; } if ($charfound == 1) { $charfound = 0; @types[$j] = "iocshArgInt"; if (/,$/) { chop($_); } @names[$j] = $_; $funcfound = 1; print "static const iocshArg " . $funcname . "Arg" . $j . " = { "; print "\"". @names[$j] . "\",". @types[$j] . " };\n"; $j++; next; } if (/char/) { $charfound = 1; next; } if (/unsigned/) { $unsfound = 1; next; } if ($intfound == 1) { $intfound = 0; @types[$j] = "iocshArgInt"; if (/,$/) { chop($_); } @names[$j] = $_; $funcfound = 1; print "static const iocshArg " . $funcname . "Arg" . $j . " = { "; print "\"". @names[$j] . "\",". @types[$j] . " };\n"; $j++; next; } if ($unsfound == 1 || /char|int|long|short/) { $unsfound = 0; $intfound = 1; next; } if ($doublefound ==1) { $doublefound = 0; @types[$j] = "iocshArgDouble"; if (/,$/) { chop($_); } @names[$j] = $_; $funcfound = 1; print "static const iocshArg " . $funcname . "Arg" . $j . " = { "; print "\"". @names[$j] . "\",". @types[$j] . " };\n"; $j++; next; } if (/double|float/) { $doublefound = 1; next; } } } # # this needs to be done one more time for the last function... # if ($funcfound == 1) { $funcfound = 0; print "static const iocshArg * const ".$funcname."Args\[" . $j ."\] = {\n"; for ($k = 0; $k < $j; $k++) { print " &" . $funcname . "Arg" . $k; if (($k + 1) < $j) { print ",\n"; } else { print "\};\n"} } print "static const iocshFuncDef " . $funcname . "FuncDef = {"; print "\"". $funcname ."\"," . $j . "\," . $funcname."Args};\n"; print "static void " . $funcname . "CallFunc\(const iocshArgBuf *args)\n"; print "{\n"; print " " . $funcname . "\("; for ($k = 0; $k < $j; $k++) { print "args\[" . $k . "\]\."; if (@types[$k] eq "iocshArgInt") { print "ival"; } if (@types[$k] eq "iocshArgString") { print "sval"; } if (@types[$k] eq "iocshArgDouble") { print "dval"; } if (($k + 1) < $j) { print ","; } else { print ");\n"} } print "}\n"; } # # end of last function work # # produce registrar function # print "\n"; print "void xxxRegister(void)\n"; print "{\n"; foreach (@outlist) { ($type, $funcname) = split(/\s+/,$_); ($funcname, $junk) = split(/\(/,$funcname); print " iocshRegister(&" . $funcname . "FuncDef, " . $funcname . "CallFunc)\;\n"; } print "}\n"; print "epicsExportRegistrar(xxxRegister)\;\n";
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
