zhangdemin99 wrote: > Dear all, > I have built ASYN on my computer, but there are some problems when > running application. It said: \dev/ttyS0 can't open Permission denied > Should I open the serial port in the Linux first or is there another > problems? what should I do next? Hi, Demin. Do you have read and write permissions on the device file /dev/ttyS0? Can you send the output of the following commands when run as the user you are running your ASYN application as: $ ls -alF /dev/ttyS0 $ groups On some Linux systems, the /dev/ttyS* device files are readable and writable by root and the uucp group. In order to be able to read and write to these device files, you need to add your user to the uucp group. This can be done with administrator privileges from an administrative account management GUI likely provided with your Linux distribution. It can also be done from the command line if you have the usermod command. A less secure approach is to make the /dev/ttyS0 device world readable and writable (run as root or as root via sudo): # chmod o+rw /dev/ttyS0 With this approach, however, if you install a kernel update or anything that may rebuild the /dev tree, your permissions change on the /dev/ttyS0 file may be lost so you'll have to go back and change it again after such an update. -lewis
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
