1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: problems in running application(ASYN)
To: "zhangdemin99" <[email protected]>, "tech-talk" <[email protected]>
Date: Wed, 6 Jun 2007 08:58:52 -0500
I'm not sure, but I think you can just change the permissions on the device as root?
vincent> su
Password:
[root@vincent epics]# ls -l /dev/ttyS0
crw-rw----  1 root uucp 4, 64 Apr 21 17:17 /dev/ttyS0
[root@vincent epics]# chmod o+rw /dev/ttyS0
crw-rw-rw-  1 root uucp 4, 64 Apr 21 17:17 /dev/ttyS0
See if that fixes the problem.
Sent: Tue 6/5/2007 9:18 PM
To: tech-talk
Subject: problems in running application(ASYN)
Dear all,
  I have built ASYN on my computer, but there are some problems when running application. It said: \dev/ttyS0 can't open Permission denied
  Should I open the serial port in the Linux first or  is there  another problems? what should I do next?
many thanks in advance.
                                     demin zhang
? ? ?,150 ? ? ? ? ? ? ? ? ? ? ? <http://event.mail.163.com/chanel/xyq.htm?from=163_NO4>
problems in running application(ASYN) zhangdemin99
Prev: problems in running application(ASYN) zhangdemin99
Next: RE: problems in running application(ASYN) Denison, PN (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
