1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Channel Archiver
To: "Szalata, Zenon M." <[email protected]>
Cc: [email protected]
Date: Wed, 16 May 2007 16:45:40 -0400
On May 16, 2007, at 16:20 , Szalata, Zenon M. wrote:
I am learning how the SNS Channel Archiver works. I am using Vlinac as channel server. In particular I am archiving the cathodeTempM quantity. Typical value is 156.6 degF. When I look at the index file with ArchiveExport tool the value is in an undesirable format, as follows:
05/16/2007 12:16:20.202837000 2e+02
I am pouring through the Channel Archiver Manuals
Always a good idea.
for information on how to change the format of the data. Actually, I do not know if the data is written to the data file in this uninformative format
As explained in the manual, the raw data as received from Channel Access
is written. For example a 'double' value.
Together with meta information like suggested display precision etc.
or it is the ArchiveExport tool that presents the data in that format.
Yes, it's a matter of presentation.
And there the problem is:
If ArchiveExport (or any other tool that looks at the data)
actually uses the display precision received via ChannelAccess,
about 45% of all users are unhappy because they never configured
the PREC fields of the records, and then miss the digits after
the decimal point.
If ArchiverExport on the other hand just uses some default precision,
the other 45% of all the users who actually configured PREC are unhappy.
Then there are the remaining 10% who deal with vacuum readings
and want exponential notation, or other cases where the meta data
received via ChannelAccess is insufficient.
The exact percentages change every few month. As did ArchiveExport.
Recent versions use the printf "%g" format as the default,
because at some point in time that seemed like a good idea.
Depending on your version, there should be some command-line switches
to select various more specific output formats as well as an option to override the
default precision:
USAGE: ArchiveExport [Options] <index file> {channel}
Options:
-format <decimal|engineering|exponential> Use specific format for numbers
-precision <int> Precision of numbers
-Kay
Re: Channel Archiver Maren Purves
Channel Archiver Szalata, Zenon M.
Prev: Channel Archiver Szalata, Zenon M.
Next: Re: Channel Archiver Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
