1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: waveform problem with asyn 4-8
To: <[email protected]>
Date: Tue, 15 May 2007 12:04:11 +0100
Hello,
I've just upgraded from using asyn 4-6 to 4-8 and discovered that a
small part of my driver support has broken. My driver support retrieves
a byte-wide array from the device and uses asyn Int32Array interface to
send this to a waveform record with the FTVL field set to "CHAR". The
new version of asyn has introduced a check of this field in
devAsynInt32Array.c initCommon and fails if the field is not set to
"LONG" or "ULONG".
As my data is only byte-wide, I don't want to fill it into a 32bit wide
array and set FTVL to "LONG" as that would send out 4 times as much
data. I guess the "proper" fix would be to implement int8Array and
int16Array interfaces in devAsyn... Is anyone up for that?
For now, I have just rebuild my own version of asyn with this particular
check commented out. This way seems to work ok for now as the client is
requesting the data type from the WF record and it seems to just "do the
right thing" and retrieves a byte-sized array. I must admit that I don't
fully understand if commenting out this type checking has any
complicated implications that may break other stuff...
Cheers,
Ulrik
  Ulrik Pedersen               phone: +44(0)1235-778580
  Software Engineer            email: [email protected]
      Diamond Light Source Ltd.
      Rutherford Appleton Laboratory,
      Chilton, Didcot
      OxfordShire OX11 0DE
Re: waveform problem with asyn 4-8 Dirk Zimoch
Prev: Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Dirk Zimoch
Next: Re: waveform problem with asyn 4-8 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Asyn Delay Maren Purves
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
