1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Asyn Delay
To: "Robert Emery" <[email protected]>, <[email protected]>
Date: Mon, 14 May 2007 18:03:31 -0500
How are your "read" records being processed.  Is each processing at 1Hz, or is it a set of records linked with FNKL links, with only the first record scanning at 1Hz.
  If it they were linked then it seems to me that the "set" messages would have to wait for at most one "read" request to process before they went to the head of the queue (since there should be at most 1 read request in the queue.  But without testing it I can't be sure.
Sent: Mon 5/14/2007 5:26 PM
To: [email protected]
Subject: Asyn Delay
I am using ASYN to communicate with 12 power supplies via an E5810
Ethernet/GPIB gateway from a Linux IOC.  I am periodically (1 sec)
reading 24 parameters from the supplies (voltage and current for each
supply) and am setting the current (3 supplies at a time) when the
operator turns a dial at the console.  The problem that I am having is
that when the current/voltage requests are processed I see about a 1 s
delay in the response to the current set messages.
It takes the power supplies about 50 ms to respond to a request for
current or voltage information.  If these requests are backing up in the
ASYN port queue, I would make sense that I would see this type of delay.
Can I speed up the processing of my current set messages by setting up a
second ASYN port on the same IOC connected to the same gateway?  With a
higher priority?  Or is there a better way to speed up my set messages?
Thanks
Rob Emery
UW Medical Center
Re: Asyn Delay Robert Emery
Prev: Asyn Delay Robert Emery
Next: Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Asyn Delay Robert Emery
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
