1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Accessing Date and Time information
To: Ralph Lange <[email protected]>
Cc: [email protected]
Date: Fri, 11 May 2007 16:13:04 -0500
Hi Ralph,
Ralph Lange wrote:
As the VxWorks strftime() does not support "%s" (seconds since the epoch), is there another reasonable way to get this number from the timestamp of a record into the value field of the same (or another) record?
Interesting question; I can't think of any _reasonable_ ways that don't involve writing some C code -- there is an unreasonable way to do it without coding, but it would be quite a sight to see!
The simplest way is to use a subroutine record, the TSEL link of the record should point to the TIME field of the record whose timestamp you want to know. The subroutine code is just:
void timeSubroutine(subRecord *prec) {
    recGblGetTimeStamp(prec);
    prec->val = prec->time.secPastEpoch;
If you want the full nanosecond accuracy, or need to adjust the epoch you could use some variant of this code:
    epicsTimeStamp epoch = {0, 0};	/* Jeff won't like this! */
    prec->val = epicsTimeDiffInSeconds(&prec->time, &epoch);
Of course you could also do this within an ai device support instead, but the subroutine record code can be used in as many record instances as you need.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Accessing Date and Time information David Dudley
Re: Accessing Date and Time information Andrew Johnson
Re: Accessing Date and Time information Ralph Lange
Prev: Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Rodney R. Porter
Next: Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Accessing Date and Time information Ralph Lange
Next: date format Graham Waters
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
