Hi Andrew,
Andrew Johnson wrote:
Yes, there's a stringin device support delivered as part of Base since
R3.14.5 that you can give an strftime string to. Eg:
record(stringin, "$(user)now")
field(DESC, "Current time and date")
field(DTYP, "Soft Timestamp")
field(INP, "@%Y-%m-%d %H:%M:%S.%03f")
If you need the fields as integers rather than strings you can use one
stringin record per field and rely on the numeric conversions built
into the database links to convert the VAL field of each record into
the appropriate integer -- not wildly efficient, but functional.
As the VxWorks strftime() does not support "%s" (seconds since the
epoch), is there another reasonable way to get this number from the
timestamp of a record into the value field of the same (or another) record?
Ralph
- Re: Accessing Date and Time information Andrew Johnson
- Accessing Date and Time information David Dudley
Re: JCA Library usage David Dudley
Re: problem using streams with asyn for Agilent E5810A Ethernet->GPIB Rodney R. Porter
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
