1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: INSTALLING IOC Applications
To: "Ernest L. Williams Jr." <[email protected]>, <[email protected]>
Cc: <[email protected]>
Date: Tue, 8 May 2007 10:58:57 +0100
Ernest,
What we do at DLS (and what I used to do in Hawaii) is to install boot
scripts in <TOP>/bin/<target arch>.
We preprocess the boot scripts (i.e. the *.cmd files) to do target
architecture specific macro substitution (to form *.boot files). So
instead of the cdCommands and envPaths files we do it all through macro
substitution in the st.cmd file. For example, the makeBaseApp.pl st.cmd
file for the application <fred> looks like this:
#!$(INSTALL)/bin/$(ARCH)/fred
## You may have to change fred to something else
## everywhere it appears in this file
cd "$(INSTALL)"
# Load binaries on architectures that need to do so.
# VXWORKS_ONLY, LINUX_ONLY and RTEMS_ONLY are macros that resolve
# to a comment symbol on architectures that are not the current
# build architecture, so they can be used liberally to do architecture
# specific things. Alternatively, you can include an architecture
# specific command file.
$(VXWORKS_ONLY)ld < bin/$(ARCH)/fred.munch
## This drvTS initializer is needed if the IOC has a hardware event
system
#TSinit
dbLoadDatabase("dbd/fred.dbd")
fred_registerRecordDeviceDriver(pdbbase)
## Load record instances
#dbLoadRecords("db/<filename>.db","<List of macros, e.g. user=xxx>")
## Set this to see messages from mySub
#mySubDebug 1
iocInit()
## Start any sequence programs
#seq sncExample,"user=xxx"
Note that, once built, this runs on all VxWorks architectures and Linux
- I don't know about RTEMS, since we don't have it here (but I must
admit that the $(VXWORKS_ONLY) macro is a bit kludgy and would welcome
better suggestions). The macro substitution idea isn't mine, it dates
from an ages old LANL application environment (but I think that used to
use colons to separate the macros - it was before we all decided to use
Note we do this all via site wide CONFIG.Dls and RULES.Dls files and so
this gets rid of another pet hate of mine - the special inclusion of
RULES.ioc file in startup directories so the build rules are different -
all Makefiles just include one RULES file and so have access to the same
set of make rules.
I can send our special RULES.Dls and CONFIG.Dls to you if you want. We
also find we need another installation directory called (we call is
data), and a DATA make target for architecture independent
configurations (such as edm screens, protocol files, archiver
configuration, alarm configuration, motor controller programs etc).
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:[email protected]]
> Sent: 07 May 2007 22:56
> To: [email protected]
> Cc: [email protected]; [email protected]
> Subject: INSTALLING IOC Applications
> Hi,
> In order to take full advantage of "INSTALL_LOCATION_APP", we need to
> install the products from iocBoot as well.  Has anyone else
> address this
> issue at their site?
> Proposal:
> Before doing a make:
> <TOP>
>   --configure
>   -- <yourAppName>App
>   -- <iocBoot>
> After doing a make:
> <TOP>
>   --configure
>   -- <yourAppName>App
>   -- <iocBoot>
>   -- bin
>   -- db
>   -- dbd
>   -- include
>   -- lib
>   -- iocStartup
>      -- ioc<yourIOCName>
>         -- st.cmd
>         -- cdCommands
>         -- envPath
> Notice, now that there is a new product directory called "iocStartup"
> Of course, now the RULE could be changed to move "iocStartup"
> along with
> bin, db, dbd, include, lib to the desired installation tree.
> Looks like clean and uninstall will work just fine as well.
> Thanks,
> Ernest
Prev: INSTALLING IOC Applications Ernest L. Williams Jr.
Next: EPICS Meeting presentations - online Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
