1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS on RTEMS
To: John Sinclair <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 2 May 2007 16:30:52 -0500
Build system answers are more reliable from Janet, but my unskilled suggestion would be to add the OS class to the assignment. Since this is a 'system' library, perhaps the right statement would be:
PROD_SYS_LIBS_RTEMS += bspExt
Janet -- can you add bspExt to the base/configure/os/ CONFIG.Common.RTEMS-mvmeXXXX files so that folks won't need to add the above line to their application makefiles?
On May 2, 2007, at 4:11 PM, John Sinclair wrote:
I guess I was missing this piece. I had to manually copy the library (could have soft-linked it) and add
USR_LIBS += bspExt
to the makefile. But then, since make is being instructed (why?) to also build the system on the host (linux-x86), this library
was missing for the linux build. I created a dummy one using ar and the build finally succeeded.
Is this the "correct" way to do EPICS with RTEMS or do I somehow have things half-configured?
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
EPICS on RTEMS John Sinclair
Re: EPICS on RTEMS Eric Norum
Re: EPICS on RTEMS John Sinclair
Prev: Re: EPICS on RTEMS John Sinclair
Next: Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: EPICS on RTEMS Heinrich du Toit
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
