1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS on RTEMS
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 02 May 2007 14:34:45 -0400
I am beginning to do some VME access from an EPICS application on RTEMS. As a first check, I
added a bit of vme access code to a device support function only to see if the application would
build. The code merely calls devRegisterAddress using atVMEA16 as the address type.
The build fails with the following errors:
/home/sinclair/rtemsEpics/supTop/R3.14.9/base/lib/RTEMS-mvme2100//libCom.a(devLibOSD.o): In function `rtmsDevInit':
../../../src/libCom/osi/os/RTEMS/devLibOSD.c:105: undefined reference to `bspExtInit'
/home/sinclair/rtemsEpics/supTop/R3.14.9/base/lib/RTEMS-mvme2100//libCom.a(devLibOSD.o): In function `rtmsDevWriteProbe':
../../../src/libCom/osi/os/RTEMS/devLibOSD.c:253: undefined reference to `bspExtMemProbe'
/home/sinclair/rtemsEpics/supTop/R3.14.9/base/lib/RTEMS-mvme2100//libCom.a(devLibOSD.o): In function `rtmsDevReadProbe':
../../../src/libCom/osi/os/RTEMS/devLibOSD.c:234: undefined reference to `bspExtMemProbe'
I have built an application using the generic RTEMS build scheme (no EPICS) that accesses the VMEbus without problems.
Any ideas as to what configuration pieces are missing?
- John Sinclair
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
Re: EPICS on RTEMS Eric Norum
Prev: Support for Omega DP40 series meters? Mark Rivers
Next: Re: EPICS on RTEMS Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
