Hi Eric,
Thanks for helping with this, sorry I misunderstood your question.
The answer is that YES it does fix the problem to put the
epicsThreadSleep(.001) in the start_routine function in osdThread.c.
Without that call to epicsThreadSleep I added print statements in
epicsThreadCreate in that same file so I could see the status returned
by pthread_create().
epicsThreadId epicsThreadCreate(const char *name,
unsigned int priority, unsigned int stackSize,
EPICSTHREADFUNC funptr,void *parm)
epicsThreadOSD *pthreadInfo;
int status;
sigset_t blockAllSig, oldSig;
epicsThreadInit();
assert(pcommonAttr);
sigfillset(&blockAllSig);
pthread_sigmask(SIG_SETMASK,&blockAllSig,&oldSig);
pthreadInfo = init_threadInfo(name,priority,stackSize,funptr,parm);
if(pthreadInfo==0) return 0;
pthreadInfo->isEpicsThread = 1;
setSchedulingPolicy(pthreadInfo,SCHED_FIFO);
pthreadInfo->isFifoScheduled = 1;
printf("Calling pthread_create\n");
status = pthread_create(&pthreadInfo->tid,&pthreadInfo->attr,
start_routine,pthreadInfo);
printf("pthread_create status=%d\n", status);
if(status==EPERM){
/* Try again without SCHED_FIFO*/
free_threadInfo(pthreadInfo);
pthreadInfo =
printf("Calling pthread_create without SCHED_INFO\n");
printf("pthread_create without SCHED_INFO status=%d\n", status);
Here is the output:
epics> threadTest 1
pthread_create status=0
Sleeping 5 seconds
epics>
epics>
epics> threadTest 0
pthread_create status=11
pthread_create error Resource temporarily unavailable
Segmentation fault (core dumped)
So pthread_create is returning status=11 (EAGAIN) when things mess up.
Any idea what this means and how to fix it? And why is the error
causing a seg fault, since it did simply return an error.
rivers@Subaru /corvette/home/epics/devel/threadTest/iocBoot/iocexample
> -----Original Message-----
> From: Eric Norum [mailto:[email protected]]
> Sent: Friday, April 27, 2007 2:10 PM
> To: Mark Rivers
> Cc: [email protected]
> Subject: Re: EPICS thread problem on cygwin-x86
> On Apr 27, 2007, at 1:58 PM, Mark Rivers wrote:
> > Eric,
> > 1) Does putting the epicsThreadSleep(.001); into the thread wrapper
> > function that actually invokes the EPICS thread fix things?
> > No. I have simplified the program even more, eliminating the
> > epicsEvent. I just spawn a thread that either returns
> immediately or
> > sleeps for .001 second. The wrapper function now sleeps
> for 5 seconds
> > after spawning the thread. It still behaves the same, i.e. if the
> > spawned thread sleeps for .001 second all is well, and the calling
> > function sleeps for 5 seconds and prints a message. If it does not
> > sleep
> > then it crashes.
> I think that I wasn't clear enough about where I meant for the delay
> to go.
> Here's the code in /src/libCom/osi/os/posix/osdThread.c which
> I meant
> when I referred to the 'wrapper' routine:
> static void * start_routine(void *arg)
> epicsThreadOSD *pthreadInfo = (epicsThreadOSD *)arg;
> int status;
> int oldtype;
> sigset_t blockAllSig;
> pthread_sigmask(SIG_SETMASK,&blockAllSig,NULL);
> status = pthread_setspecific(getpthreadInfo,arg);
> checkStatusQuit(status,"pthread_setspecific","start_routine");
> status = pthread_setcanceltype
> (PTHREAD_CANCEL_ASYNCHRONOUS,&oldtype);
> checkStatusQuit(status,"pthread_setcanceltype","start_routine");
> status = mutexLock(&listLock);
> checkStatusQuit(status,"pthread_mutex_lock","start_routine");
> ellAdd(&pthreadList,&pthreadInfo->node);
> pthreadInfo->isOnThreadList = 1;
> status = pthread_mutex_unlock(&listLock);
> checkStatusQuit(status,"pthread_mutex_unlock","start_routine");
> (*pthreadInfo->createFunc)(pthreadInfo->createArg);
> epicsExitCallAtThreadExits ();
> return(0);
> Does putting the delay just before the free_threadInfo call
> fix things?
> > 2) Have you tried running this under gdb to see where the crash
> > occurs?
> > I have found that gdb under Cygwin does not run the threaded EPICS
> > applications at all. Maybe I'm doing something wrong, but what
> > works on
> > Linux does not work on Cygwin. Furthermore, Cygwin does
> not produce a
> > useful core file. It produces a file called, in this case
> > "threadTest.exe.stackdump", but it simply contains:
> > $ cat threadTest.exe.stackdump
> > Exception: STATUS_ACCESS_VIOLATION at eip=004A05B6
> > eax=DF0DF046 ebx=004E6F60 ecx=6112CB58 edx=005A2DC0 esi=005A2DC0
> > edi=610E30A0
> > ebp=0022EDD8 esp=0022EDD4
> > program=j:\epics\devel\threadTest\bin\cygwin-x86\threadTest.exe, pid
> > 4028, thread main
> > cs=001B ds=0023 es=0023 fs=003B gs=0000 ss=0023
> > Stack trace:
> > Frame Function Args
> > 0022EDD8 004A05B6 (004E6F60, 005A2DC0, 0022EE08, 005A2DC8)
> > 0022EDF8 004918A7 (610E30A0, 004D94F4, 004D9747, 6110A4F0)
> > 0022EE28 0049220E (004C9438, 0000000A, 00020000, 00401520)
> > 0022EE48 00401593 (00543BD8, 0022EEE8, 00000000, 005407A4)
> > 0022EEF8 00418070 (61157780, FFFFFFFF, 00000000, 004015F3)
> > 0022EF18 0040161E (00000002, 61157668, 00540090, 77FA88F0)
> > 0022EFD8 61004DD2 (0022EFF0, 00000000, 0022F221, 33323430)
> > 0022FF88 6100594F (00000000, 00000000, 00000000, 00000000)
> > End of stack trace
> Hmmmmm...
> not too useful.
> Eric Norum <[email protected]>
> Advanced Photon Source
> Argonne National Laboratory
> (630) 252-4793
- Re: EPICS thread problem on cygwin-x86 Benjamin Franksen
- Re: EPICS thread problem on cygwin-x86 Eric Norum
Controls Positions at SNS Gurd, David P.
<2007>
<2007>
