Folks,
I have found a problem with EPICS threads on cygwin-x86. The problem
showed up when doing the command "asynReport" with the "details"
argument=0 (default). The IOC crashes when this is done. It is a
timing
problem with the thread that asynReport creates.
I have come up with a very simple test program to demonstrate the
problem:
#include <epicsEvent.h>
#include <epicsThread.h>
#include <epicsExport.h>
#include <iocsh.h>
typedef struct myArgs {
epicsEventId done;
int delay;
} myArgs;
static void myThread(myArgs *pArgs)
if (pArgs->delay) epicsThreadSleep(.001);
epicsEventSignal(pArgs->done);
static void threadTest(int delay)
myArgs args;
epicsEventId done = epicsEventMustCreate(epicsEventEmpty);
args.delay = delay;
args.done = done;
epicsThreadCreate("myThread",
epicsThreadPriorityLow,
epicsThreadGetStackSize(epicsThreadStackSmall),
(EPICSTHREADFUNC)myThread, &args);
epicsEventMustWait(done);
epicsEventDestroy(done);
/* iocsh functions */
static const iocshArg threadArg0 = {"Delay", iocshArgInt};
static const iocshArg * const threadArgs[1] = {&threadArg0};
static const iocshFuncDef threadTestFuncDef= {"threadTest", 1,
threadArgs};
static void threadTestCallFunc(const iocshArgBuf *args)
threadTest(args[0].ival);
static void threadTestRegister(void)
iocshRegister(&threadTestFuncDef, threadTestCallFunc);
epicsExportRegistrar(threadTestRegister);
The function threadTest() simply creates a thread, and then waits
for it
to complete with epicsEventMustWait().
If the delay argument is non-zero the thread sleeps for 0.001 second.
It then signals the event and returns.
On Linux this program works fine.
However, on Cygwin it crashes if delay is 0, i.e. if it does not sleep
for .001 second.
$ ../../bin/cygwin-x86/threadTest.exe st.cmd
#!../../bin/linux-x86/example
## You may have to change example to something else
## everywhere it appears in this file
#< envPaths
dbLoadDatabase("../../dbd/threadTest.dbd",0,0)
threadTest_registerRecordDeviceDriver(pdbbase)
iocInit()
Starting iocInit
### EPICS IOC CORE built on Aug 25 2006
### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
iocInit: All initialization complete
epics> threadTest 1
epics> threadTest 0
pthread_create error Resource temporarily unavailable
Segmentation fault (core dumped)
This is a serious problem, since any thread that returns too quickly
causes a crash on Cygwin.
Can someone who knows about EPICS threads figure out why this is
crashing, and how to fix it?
<threadTest.c>
<threadTestInclude.dbd>
<threadTestMain.cpp>
<Makefile>
