I have updated my version of CA-Python interface module.
Please find a new tar.gz file as an attachment to this e-mail.
It may have multi core CPU(such as Intel Core Duo on my MacBook).
As far as I tested, it runs stable on a single core processors, i686 and
PPC.
Best regards,
Noboru
Zhong Ren wrote:
> Dear Noboru,
> Thank you. I must say the KEK CaPython314 is very easy to use.
> I am not surprised that your little test below won't crash,
> since it does not contain a wx.Timer. In order to repeat my
> crash, a wx.Timer must be constructed, it must be bound to a
> onTimer function, and it must be started. Using
> threading.Timer instead of wx.Timer will not cause the crash.
> I cannot tell who is guilty, wx.Timer or CaPython314. I also
> have the feeling that Python 2.5 may be the problem.
> Zhong
> ---- Original message ----
>> Date: Wed, 06 Dec 2006 10:47:29 +0900
>> From: Noboru Yamamoto <[email protected]>
>> Subject: Re: wxPython timer and KEK CaPython314 cause core dump
>> To: [email protected]
>> Cc: [email protected]
>> Hi,
>> I'm not familiar with WxPytho (yet).
>> But, the following code works on MacBook running MacOSX
> 10.4.8 with
>> Python2.5,
> wxPython2.7-osx-unicode-2.7.2.0-universal10.4-py2.5.dmg
>> and KEK version of CaPython314 ( I should have used the
> different name
>> to avoid confusion with FNAL version. Sorry).
>> import wx,ca
>> class MyApp(wx.PySimpleApp):
>> def OnInit(self):
>> frame = wx.Frame(None, -1, "Hello from wxPython")
>> frame.Show(True)
>> self.frame=frame
>> self.ch=ca.channel("fred")
>> self.ch.wait_conn()
>> self.ch.monitor(self.ca_callback)
>> self.ch.flush()
>> self.SetTopWindow(frame)
>> return True
>> def ca_callback(self,valstat):
>> self.ch.update_val(valstat)
>> self.frame.Title="%s:%f"%(self.ch.name,self.ch.val)
>> if __name__ == "__main__":
>> app = MyApp(0)
>> app.MainLoop()
>> I hope this can give some idea.
>> Regards,
>> Noboru Yamamoto
>> EPICS group/J-PARC control group
>> KEK, JAPAN
>> Zhong Ren wrote:
>>> I managed to isolate a core dump in a minimized Python code
>>> (see below). I found two components are essential to cause a
>>> core dump: wx.Timer and ca.Monitor (or ca.Get). Can someone
>>> tell what the problem is?
>>> import wx
>>> import ca
>>> def onTimer(event): pass
>>> ca.Monitor('S:SRcurrentAI')
>>> appli = wx.PySimpleApp()
>>> frame = wx.Frame(None)
>>> timer = wx.Timer()
>>> timer.Bind(wx.EVT_TIMER, onTimer)
>>> timer.Start(milliseconds = 10, oneShot = False)
>>> appli.MainLoop()
>>> Other info:
>>> Pyhton 2.5
>>> wxPython 2.6.3.3
>>> RedHat Linux x86_64
>>> GCC 4.1.1
>>> To test, let the routine run for a while. A core dump will
>>> occur in a few minutes.
>> ________________
CaPython-1.7.tar.gz
Description: GNU Zip compressed data
begin:vcard
fn:Noboru Yamamoto
n:Yamamoto;Noboru
email;internet:[email protected]
tel;work:+81-29-864-1171, ext. 5209
tel;fax:+81-29-879-6130
x-mozilla-html:FALSE
version:2.1
end:vcard
Re: Problem building shareable libraries on win32-x86 Ernest L. Williams Jr.
EPICS thread problem on cygwin-x86 Mark Rivers
<2007>
Re: wxPython timer and KEK CaPython314 cause core dump Zhong Ren
<2007>
