1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: nexplained hangup in semTake(), Re: channel access security deadlock from asInit()
To: Kay-Uwe Kasemir <[email protected]>
Cc: tech talk <[email protected]>
Date: Wed, 18 Apr 2007 12:27:44 -0700
Wonderful occasion to make the case for an open-source OS:
Attach a debugger, look at the list of tasks blocking on the semaphore.
Then look at who currently holds it and what that task is waiting for.
Should not be hard to find the deadlocked cycle (with a debugger +
access to the OS source that is)...
-- Till
Kay-Uwe Kasemir wrote:
On Apr 18, 2007, at 14:56 , Jeff Hill wrote:
You have the thread that has the AS lock and is calling rsrv where it is
taking its lock...
If it's a classic deadlock then we need to find the other half of the bug.
I understand, but I can't get that information.
When I type asInit() and then CTRL-C, I get that one stack trace.
But from then on, the IOC shell is hung, no more telnet or serial
line access, only a hard reboot or power cycle,
so I don't get to look at other threads.
CPU consumption was no issue up to that hangup,
and afterwards, I can't say because I have to reboot.
So in the interest of political correctness,
we can call this an unexplained hangup in semTake()
instead of a deadlock.
-Kay
channel access security deadlock from asInit() Kay-Uwe Kasemir
RE: channel access security deadlock from asInit() Jeff Hill
nexplained hangup in semTake(), Re: channel access security deadlock from asInit() Kay-Uwe Kasemir
Prev: nexplained hangup in semTake(), Re: channel access security deadlock from asInit() Kay-Uwe Kasemir
Next: Re: Unexplained hangup in semTake(), Re: channel access security deadlock from asInit() Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
