Ned -
I thought about this, too ... and I would completely understand if the
CA server does not grant access (neither read nor write) to any channels
in that case.
But actually it doesn't even resolve the names anymore, which is a
different thing, misleading, and probably neither appropriate nor intended.
Ralph
Ned D. Arnold wrote:
Ralph -
I think the behavior that you observed is by design ... if one tries
to specify a configuration file that does not exist, it means you
intended to have *some* access control in place. If the file doesn't
exist, this is a fatal error and the safest thing to do is not allow
any access at all so someone will fix the problem immediately.
I actually remember this discussion with Marty Kraimer about 16 years
ago ...
Ned
- channel access security deadlock from asInit() Kay-Uwe Kasemir
- Re: channel access security deadlock from asInit() Ralph Lange
- Re: channel access security deadlock from asInit() Ned D. Arnold
Re: channel access security deadlock from asInit() Kay-Uwe Kasemir
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
