Hi Glen,
White, Glen Russell wrote:
I have built epics base (V 3.14.8) successfully, but I get the below
error when trying to build asyn (v. 4-7) which I don't know how to
interpret. Can anyone point me at a possible problem here?
I'm pretty sure this is a line-ending problem; your cygwin is probably
set up to expect Unix line-endings (\n => 0x0a), but the file you're
giving it has DOS line-endings (\n => 0x0d, 0x0a). This probably
explains why the error message below doesn't make very much sense:
/cygdrive/c/epics-3.14.8/base/bin/win32-x86-cygwin/dbToRecordtypeH.exe -I . -I .. -I ../../dbd -I /cygdrive/c/epics-3.14.8/base/dbd ../../asyn/asynRecord/asynRecord.dbd ../O.Common/asynRecord.h
Error Last token ""dbCommon.dbd""
input line: include "dbCommon.dbd"
in: file ../../asyn/asynRecord/asynRecord.dbd line 107
db_parse returned -1
Terminal error For input file ../../asyn/asynRecord/asynRecord.dbd
There are various ways to solve it - changing cygwin to use the DOS
line-ending conventions, or change the source file to use the Unix
conventions. If you used winzip to untar the asyn distribution that
might explain how this happened, because it would have put the DOS
line-endings in.
I think we tried to fix this kind of problem in some later versions, but
I don't know that we solved all of the possible locations.
HTH,
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
- RE: Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin White, Glen Russell
- Building asyn4-7 with epics-3.14.8 under win32-x86-cygwin White, Glen Russell
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
