1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Motor Record - OMS58 Driver
To: "EPICS Tech Talk" <[email protected]>
Date: Mon, 16 Apr 2007 08:44:15 +0100
This is the very same issue I experienced when migrating my application
from R3.13.9 to R3.14. I concur with Ron about the undocumented change
in parameters. On dropping the 'Number of axes' parameter, it all sprang
into life! It took me a couple of days to track it down.
Ian
-----Original Message-----
Sent: 13 April 2007 15:40
To: Ralph Lange
Cc: EPICS Tech Talk
Subject: Re: Motor Record - OMS58 Driver
Ralph,
If you look at the "Known Problems" from R5-4 to R5-9 on the motor
record web page;
http://www.aps.anl.gov/upd/people/sluiter/epics/motor/index.html
you will find the following;
>    1. An undocumented change was made in R5-4 to two OMS setup
>       functions. Namely, the unused 2nd argument ("axes per card") was
>       eliminated from omsSetup() and oms58Setup().
In other words, the 2nd argument was eliminated.  That is probably your
problem.
Ron
Ralph Lange wrote:
> Hi -
> I'm moving a stepper motor application using an OMS VME58 card:
>   from EPICS 3.13.9 / motor 4.9.3   to   EPICS 3.14.8.2 / motor 6.1
> In the old setup everything works fine, in the new setup the driver
> claims that it doesn't find the VME58 motor card. Hardware settings
> are unchanged, the setup call in the st.cmd is the same.
> Searching the release notes of the motor record I did not find
> anything that I found applicable to my problem.
> Before I dig into the code: Is there anything obvious that I didn't
> see? Similar effects somewhere?
> HW: vxWorks 5.4.2, mv2100, OMS VME58, test stand with no other VME
cards.
> Thanks a lot!
> Ralph
Re: Motor Record - OMS58 Driver Ralph Lange
Re: Motor Record - OMS58 Driver Ronald L. Sluiter
Prev: Re: Motor Record - OMS58 Driver Ronald L. Sluiter
Next: Re: Motor Record - OMS58 Driver Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
