Ralph,
If you look at the "Known Problems" from R5-4 to R5-9 on the motor
record web page;
http://www.aps.anl.gov/upd/people/sluiter/epics/motor/index.html
you will find the following;
1. An undocumented change was made in R5-4 to two OMS setup
functions. Namely, the unused 2nd argument ("axes per card") was
eliminated from omsSetup() and oms58Setup().
In other words, the 2nd argument was eliminated. That is probably your
problem.
Ron
Ralph Lange wrote:
Hi -
I'm moving a stepper motor application using an OMS VME58 card:
from EPICS 3.13.9 / motor 4.9.3 to EPICS 3.14.8.2 / motor 6.1
In the old setup everything works fine, in the new setup the driver
claims that it doesn't find the VME58 motor card. Hardware settings
are unchanged, the setup call in the st.cmd is the same.
Searching the release notes of the motor record I did not find
anything that I found applicable to my problem.
Before I dig into the code: Is there anything obvious that I didn't
see? Similar effects somewhere?
HW: vxWorks 5.4.2, mv2100, OMS VME58, test stand with no other VME cards.
Thanks a lot!
Ralph
- RE: Motor Record - OMS58 Driver Gillingham, IJ (Ian)
- Motor Record - OMS58 Driver Ralph Lange
Re: Motor Record - OMS58 Driver Martin L. Smith
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
