I'm moving a stepper motor application using an OMS VME58 card: from EPICS 3.13.9 / motor 4.9.3 to EPICS 3.14.8.2 / motor 6.1 In the old setup everything works fine, in the new setup the driver claims that it doesn't find the VME58 motor card. Hardware settings are unchanged, the setup call in the st.cmd is the same. Searching the release notes of the motor record I did not find anything that I found applicable to my problem. Before I dig into the code: Is there anything obvious that I didn't see? Similar effects somewhere? HW: vxWorks 5.4.2, mv2100, OMS VME58, test stand with no other VME cards. Thanks a lot! Ralph
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
